1 members (KEVINSKI),
63
Mod | | | Forums66 Topics128,009 Posts1,055,291 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13482 05/07/2004 5:36 AM | Joined: Mar 2003 Posts: 19 Junior Member | | Junior Member Joined: Mar 2003 Posts: 19 | I know this is a question that has been answered before but humor me. I purchased a 53 1/2 ton 3100 series from the original owner who told me the truck was all original. The truck has a 235 that the owner says was a swap done at the dealership because of reoccuring problems with the 216. Has anyone heard of this before? | | |
#13483 05/07/2004 4:04 PM | Joined: Jan 2003 Posts: 24 Junior Member | | Junior Member Joined: Jan 2003 Posts: 24 | I can't offer you a lot of insight, but I am in a similar situation. I have a '51 that was built with a 216, but it is now sporting an old splash-oil 235. Because the 235 is so old, I am assuming that the swap was done either right when the truck was new, or within its first year or two. So swapping out a 216 right off the bat isn't completly unheard of.
Rob | | |
#13484 05/07/2004 5:11 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I just took a running 216 out of my 53'. It is the original engine and I have no use for it. Complete pan to carb if anyone's interested. | | |
#13485 05/07/2004 8:00 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The 216 is a very reliable engine. The only recurring problems that occured were due to neglect and/or abuse.
Fred 52 3600 69 C-10
#13486 05/08/2004 1:51 PM | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | I have a 38 that was re-engined in 42 because the owner felt the original just wasn't right. They also retitled as a 42. I asked my Grandmother about that as She worked for a dealer about that time and she said that was fairly common back then. | | |
#13487 05/08/2004 2:48 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Anchorage, Check the casted numbers on the block to see when the engine was made. It will help you determine if the 235 you have was possibly around when the truck was new.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
