6 members (78buckshot, Gdads51, KEVINSKI, dt235sd, Peggy M, 1 invisible), 178 guests, and 1 robot.
Topics128,081
Posts1,056,069
Members48,434
#1342657 01/18/2020 3:30 AM
Was over at another shop and saw what I thought was a neat trick on a 52 Burb. Not the shop but the owner had used a 5'x10' piece of 1/8" panel or plywood (?) on top of probably a two piece sub floor. A 5x10 is big enough for a one piece floor. The shop owner said the man told him he bowed the center up till the sides went under the side rails. Don't know how weather proof a layered floor would be but it looked nice.
Evan
Thanks for sharing, Evan.
In fact, I "almost" ordered and oversize sheet to do that on my 52panel but the original was good so I decided to "fill" the places where stuff was dragged out the back door, and the ply's were showing, since I was going to put a thin carpet mat on top of it.
.......but this is food for thought for anyone wrestling with the problem.
That is a very clever solution.
However, how do you deal with replacing the 47-55st Suburban’s grooved linoleum cover mat/sheet?
I actually just logged in to ask if anyone has ever bought high durometer rubber rolls to replace the original battleship linoleum and used a tool to groove it like the original flooring?
I am in the process of attempting this. I ordered some sample rubber and will be creating a metal slotted guide to run a woodworkers V notching tool through at the most appropriate depth to replicate the original look.
I'll post back with whether this idea goes up in flames or works out.
Thanks, swizcore
Ok I have received my rubber samples and notching tool and performed a hand-test only but I am happy with the results.
(Please disregard the fact that my cut line is not straight lol)
Now I will cut my metal-slot guide to cut an actual consistent sample. I believe this process will work out like I envisioned though.
https://i.postimg.cc/8JJrWFWB/IMG-0355.png
https://i.postimg.cc/jWjfx3S1/IMG-0356.png
https://i.postimg.cc/GBSyHPBm/IMG-0359.png
https://i.postimg.cc/phw5B2JN/IMG-0360.png
Looking good swizcore. Please keep us posted with updates as you move along. Thanks for sharing.
