8 members (55shaker, MickeyP, Bill Hanlon, 3B, Gdads51, Ridgeback, Gray_Ghost, 32Fordpuchoptop),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,118 Posts1,056,304 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Was over at another shop and saw what I thought was a neat trick on a 52 Burb. Not the shop but the owner had used a 5'x10' piece of 1/8" panel or plywood (?) on top of probably a two piece sub floor. A 5x10 is big enough for a one piece floor. The shop owner said the man told him he bowed the center up till the sides went under the side rails. Don't know how weather proof a layered floor would be but it looked nice.
Evan
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks for sharing, Evan. In fact, I "almost" ordered and oversize sheet to do that on my 52panel but the original was good so I decided to "fill" the places where stuff was dragged out the back door, and the ply's were showing, since I was going to put a thin carpet mat on top of it.
.......but this is food for thought for anyone wrestling with the problem. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That is a very clever solution.
However, how do you deal with replacing the 47-55st Suburban’s grooved linoleum cover mat/sheet? | | | | | Joined: Oct 2018 Posts: 27 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 27 | That is a very clever solution.
However, how do you deal with replacing the 47-55st Suburban’s grooved linoleum cover mat/sheet? I actually just logged in to ask if anyone has ever bought high durometer rubber rolls to replace the original battleship linoleum and used a tool to groove it like the original flooring? I am in the process of attempting this. I ordered some sample rubber and will be creating a metal slotted guide to run a woodworkers V notching tool through at the most appropriate depth to replicate the original look. I'll post back with whether this idea goes up in flames or works out. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Looking good swizcore. Please keep us posted with updates as you move along. Thanks for sharing. | | |
