1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
Apprentice
Apprentice
1 Offline
This is my first post on these boards and I am glad that I found this place !!
I have an early 1946 Chevrolet 1/2 Ton Truck. I am going to start making a rod out of it this fall. It looks like I will be going with a 350 engine, TH350 trans, and a Mustang II aftermarket front end. Can anyone suggest a good rearend for this truck? I am looking for something that will bolt in without much modification and disc brakes would be nice also.
I would also like to hear from anyone who has a 1941-46 that has been rodded. What kind of troubles or road blocks that you ran in to....
I put a Chev Nova rear end in my 46, haven't driven it yet but it looks alright. took it all apart to check the gears etc, everything looked good so sealed it back up, sanded and painted it and it looks like new. Had to rebuild the rear brakes and cylinders but thats normal. My 46 also has a Chev S10 front end. Trying to fit the 350 drivetrain was tricky but I got it in. Looks a little narrow in the front end but wide tires will cure that. Good luck in finding a good differential. Bob T
do a search here on the bolt....or better still look in the tech tips ..there is a listing here somewhere that gives you the widths of a lot of rear ends that could be donors. I bet one is out there that you don't know about and can get it for free!!!!!!
The S-10 4x4 rears fit nicely and they are everywhere, should be cheap.
1946 1/2-Ton Chevy
Apprentice
Apprentice
1 Offline
Thanks for the replys !!
What year s10 4x4 should I look for and will those rear ends takes some abuse? Also do you know the gear ratio?
Used a 72 cougar 9" under mine. amount 61" mount to mount. Worked perfect.
Heres a site that may help you.
http://50chevy.freeservers.com/Suspension_Widths.html#Suspension
stea, do you have the narrower bed in 39? what size rims and tires are you running and and what is the backspacing?
Look for a ZR 2 off road s-10, the later ones have a narrowed 10 bolt from the '88-'98 fullsize truck, but with the 5 on 4 3/4" bolt circle and the '99 and up had a disk brake option.
Bill Burmeister
Nope, the 39 GMC actually used the wider 40-46 bed. Rims are 7" with 4" backspacing on the front and 5" backspacing on the back.. Rear tires are 235 60 15 and the fronts are 205 60 15.
Heres a new pic with the new rims and tires.
http://hotrodders.com/gallery/data/500/medium/IMGP0249.JPG
I
I Offline
I'm running a '67-'69 Camaro 12 bolt(same as Nova,Firebird, I believe) under my '46 panel.Spring perches lined up, fabed shock mounts.These are the narrowest, 10" wheels and 295's protrude a bit, 8.5 would go under the fenders.Right now the 12 bolt -posi is probably worth more than the whole rest of the truck, but a non-posi 10 bolt should do much cheaper.
