| | | Forums66 Topics128,194 Posts1,057,263 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I need a fair amount of 3/16" and 3/8" SS line for my project. The best prices I have found are about $3 and $4 a foot respectivly. I think I should be able to find a better deal than that on say 30 or 40 feet of each. Any one have a lead on beter prices? Thanks, Grigg
Last time I bought some I got it from Inline Tube, I don't really want to deal with them again if given a choice. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You may want to check Speedway motors. I know that they carry stainless line, but i'm not sure about pricing.
Bill Burmeister | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Thanks, I checked speedway motors, there products are kinda hard to search on the site, I did not find much.
I did check McMaster Carr, and they have the best price by far for 3/8" stainless in a 50 foot coil. Just over $1 a foot, I can live with that. They don't list a coil of 3/16", but I'll call and ask about that. They do sell it in 6' lengths, but I need some longer.
Grigg | | | | | Joined: Feb 2003 Posts: 33 Junior Member | | Junior Member Joined: Feb 2003 Posts: 33 | Summit racing sells coils of stainless,mild steel,and aluminum,the stainless is I think about $30 for 20 or 25 feet of it,I used it doing the brake lines on my 71 camaro,it wa real difficult to get a good flare on the ends for the fittings though. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | here is the one for 3/16" http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D220236&N=4294924496+115&autoview=sku And for 3/8" http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D220238&N=4294924496+115&autoview=sku And the tube nuts http://store.summitracing.com/egnse...ordSearch&DDS=1&N=4294924496+115 So it looks like summit for everything but the 3/8" that is cheaper at McMaster Carr. I have made a bunch of stainless lines before, and a top of the line flaring tool is a must. Thanks for your help, Grigg | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Keep in mind you don't have to double flare stainless. A regular flare is all they need. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | For brake lines I think it wise to double flare. It may even be the law? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Not on stainless, it'll crack. Stainless line uses different fittings and a different angle on the flare from standard steel, 37 1/2 degrees instead of 45. I don't think there are any laws, other than the laws of physics, involved. I can say that single flares on plain steel will leak.
Bill Burmeister | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have seccusfully double flared at 45 degrees nine different 3/16" stainless brake lines on my truck, with about 12,000 miles in two years I have had no problems. All I have read on the subject reccomend the method I used for stainless brake lines.
There are two common types of flarred tube connections. The 45 degree and the 37.5 degree.
45 is used with a single flare sometimes. For brake lines I belive, but am not sure, that a double flare is required by law in the US. Regardless of a law or not the 45 degree double flare is stronger, less likely to crack in the flare, and more likely to seal than a single flare.
The 37.5 degree flare is never double flared that I know of. It does require a backup sleve for better support of the flare in the fitting to reduce the likely hood of the flared part breaking off.
All materials can be flared either way.
I may not be 100% right about all this but I have tried to indicate where I am unsure. There are some quite good profesional explinations out there on the web explaning the different types of tube connections and there uses. I suggest yall look them up before doing any sort of critical plumbing job like brake or fuel lines. I'll try and post a link to a better explination when I find one.
Grigg | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Learn somthing new all the time! I was always told that you couldn't double flare stainless, and most kits that I had seen used the single flare with the sleeves. I suppose that it would depend on the grade of stainless tube that would determinr whether it can be double flared or not. I will say that I would prefer a double flare on brake/feul line due to the extra strength.
Bill Burmeister | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Do note that stainless is hard to double flare and the best flarring tool money can buy is a good investment.
Stainless should also be annealed. Some is to hard to flare, be carefull what you buy. | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | I double flared mine, with an inexpensive flaring tool (new).. no leaks so far... but I used the longest prefabbed lines I could find, bent and cut them down as I needed to.
| | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Hi All, Just got the recent Eastwood catalog. They carry 3/16" and 1/4" brake line kits. You get 20' of stainless tube, and 16 assorted SAE double flare SS fittings. $69.99 for the 3/16 kit and $79.99 for the the 1/4" kit. I know this is no help to you Grigg because you need 3/8" but I thought the others might find this interesting. Rick | | | | | Joined: Jan 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 63 | Try Inline Tube. Good products. here's a link. http://www.inlinetube.com/
1941 AK named "PETEY" my buddy.
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I bought my SS brake lines from a firm called Classic Tube . They deal primarily in prebent applications; I'm not sure if they sell it in bulk or not. I copped out and bought the prebent/preflared lines because I was doing the brake job in an unheated quonset hut in December, and didn't want to screw around with bending cold stainless steel tubing. Classic Tube was very, VERY good to deal with. Aside from a shipping error -- which they fixed that same day -- I had no problems. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I just checked out Classic Tube, they do have bulk line in 20' lengths. They have it up to 1/2" dia. They have all the fittings and the wire wrap too.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 23 Junior Member | | Junior Member Joined: Apr 2005 Posts: 23 | how about SSBC Stainless Steel Brakes Corporation, www.ssbrakes.com | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | if you can work with 18",24",36" and 5 ft lengths why not get them from NAPA. They have to order them but I found them to be nice. It just takes some planning but I do realize some folks don't want to join the pieces. I did several years ago and still no problems. | | |
