4 members (Donf, FAST55, Shaffer's1950, greenie-reddy), 34 guests, and 3 robots.
Topics128,154
Posts1,056,838
Members48,456
Q
Q Offline
I have a 1937 Chevrolet pickup the rear spring shackles have pushed outward . How to I fix this?
Qball
Red dot, center of chest ...
Looks like the bushings are worn out.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Are those original shackle plates? I have just finished my 37 and mine do not look like that. Also where are you located in Michigan? Bill
1937 GC
Pins and bushings are stuffed . Buy new ones . One of the vendors on this site will have them .
scroll all the way to the bottom for various 1937 spring/suspension parts.
It also appears the rear shackle has took a hit to me..........take the shackle loose, make sure the springs align with the front shackle in correlation with the rear housing mount as well. A new set of bushings and plates should complete the job......and be sure to check out the front hangers as well.
FYI Those aren’t original shackles. The OEM have a single bolt in between the two bushings. And no rubber. Original spring mount was riveted on.
1937 Chevy 1/2 ton panel
Q
Q Offline
Yes I am in Michigan I know the bushings are wore out but if I change them it will not solve the problem of the springs pushed outside of the frame
Qball
Q
Q Offline
I know that I need new bushings and springs but that doesn’t fix the problem of the springs being pushed outside the frame
Qball
Q
Q Offline
The front is good both rears look the same it’s almost like the springs moved out on the axle an inch on both sides is that possible?
Qball
Q
Q Offline
The spring mount is riveted on
Qball
Q
Q Offline
The mount is bolted on so does the original one mount to outside the frame?
Qball
Here is a rear spring mount
1937 GC
Q
Q Offline
Armada
Qball
Q
Q Offline
So obviously I have the wrong shackles if I was to purchase new ones this will not solve my problem here the springs are outside the frame an inch
Qball
Does the rear axle look original? Are both sides pushed out at the rear? If both are out, the axle mounting pads are to wide splaying the springs out at the rear. If it's only one side, then the locating pin on the leaf spring could be sheered off from some sort of damage, this will angle the spring out just as you have.
You should pull the axle loose from the spring to confirm no damage, then replace all the shackles and bushings. '37 spring bushings are made from a bronze alloy with a steel pin through them, you will need to keep them greased quite often. Also, don't over tighten the center shackle bolt either, just tight enough to not bend the plate is about right.
On a side note, when the springs are out, pull them apart and grind off any steps that may have been worn into them from use, and to help in the ride quality, add Poly-slide spring liner between each leaf.
I measured my spring. The outside of spring eye is outside the frame approximately 1/2".
1937 GC
