7 members (JW51, baldeagle, Oswald, Gdads51, Jay R, greenie-reddy, 1 invisible),
43
Mod | | | Forums66 Topics128,004 Posts1,055,247 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | You may have seen these but some of you may not.....I always called them Chicken ties as we used them to tie the gags on roosters back in my gamecock fighting days!! https://www.griplockties.com/ | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | I’ve always hated that you can only use a zip tie once and then have to throw it away. This reusable tie is a good idea.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Mar 2007 Posts: 3,370 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,370 | I’ve always hated that you can only use a zip tie once and then have to throw it away. This reusable tie is a good idea. I just use the end of a scribe to open the zip tie, you can reuse them over and over if you don't break the lock.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | I just use the end of a scribe to open the zip tie, you can reuse them over and over if you don't break the lock.  Yeah, I'm a cheap SOB too.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Ive actually seen on big size wire ties, a sorta thunb lever to unlock em. The lever was only about half the size of ofthe cable and worked great. I thought it was ingenious. | | | | | Joined: Mar 2007 Posts: 3,370 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,370 | I'm not cheap just to sorry to pick up another pack at HF
