3 members (Hotrod Lincoln, BC59, 1 invisible), 134 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#1342921 01/20/2020 6:18 AM
I had my frame blasted down to shiny metal. I applied satin Chassis Saver on it. Not totally satisfied but it will do. What have the rest of you used?
Bed Liner on the Frame and running boards............
...I"m a POR15 fan.....put it on my 52 Panel after blasting the chassis and it has looked super good for over 7 years now and I do drive my vehicles. That is some tough stuff.......just be sure to follow safety directions, wear old clothes and gloves. This stuff takes weeks to wear off your hands!!
Insomniac
Insomniac
Endura epoxy paint. Very tough.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I used the chassis saver also on my ford ranger it seems to work good it is similar to por 15 you will have to cover over it if the sun gets at it as it will peel off ,I think por 15 is same .chassis saver is also pretty tough I put fibreglass cloth on with the paint on my floor boards and it hardened like a rock seems to be holding up it has been 3 years
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Rocket man #1343020 01/21/2020 12:03 AM
Powder coat.
Rocket man #1343024 01/21/2020 12:15 AM
Powder coating in my area in my experience is not very good .corrosion gets under and the powder coat and flakes off . When I sanded my rims that were powder coated they were very difficult to sand and spots that were still shinny looking chipped off and there was rust underneath ,making it difficult to tell were the rust was .l ended up using sandblaster to get it all .my trailer was the same looked good until one use in the winter coating started flaking and the rust seemed to hid under until the coating chipped off .
"The Journey"
Follow in the DITY
Sandblast.
Epoxy prime.
Rustoleum gloss black.
I had one sandblasted and powder coated. Rust has already popped up through cracks at a few rivet heads. Now I can't do anything about it because its hard to touch up powder coat.
Rusty spots such as this on painted frames can easily be treated and touched up with a rattle can o Rustoleum.
KEVINSKI #1343135 01/21/2020 6:45 PM
Did I mention that I live in So Cal? Sorry.
Yea the powder coat in your area probably lasts a lot longer than here . Today I look outside and see snowbanks you have to be careful backing out of the driveway because there blocking your view.
"The Journey"
Follow in the DITY
After sandblasting, I applied epoxy primer and then industrial enamel black.
