2 members (joe apple, jmoore),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | I had my frame blasted down to shiny metal. I applied satin Chassis Saver on it. Not totally satisfied but it will do. What have the rest of you used? | | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | Bed Liner on the Frame and running boards............ | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...I"m a POR15 fan.....put it on my 52 Panel after blasting the chassis and it has looked super good for over 7 years now and I do drive my vehicles. That is some tough stuff.......just be sure to follow safety directions, wear old clothes and gloves. This stuff takes weeks to wear off your hands!! | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | Endura epoxy paint. Very tough.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | I used the chassis saver also on my ford ranger it seems to work good it is similar to por 15 you will have to cover over it if the sun gets at it as it will peel off ,I think por 15 is same .chassis saver is also pretty tough I put fibreglass cloth on with the paint on my floor boards and it hardened like a rock seems to be holding up it has been 3 years | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | | | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | Powder coating in my area in my experience is not very good .corrosion gets under and the powder coat and flakes off . When I sanded my rims that were powder coated they were very difficult to sand and spots that were still shinny looking chipped off and there was rust underneath ,making it difficult to tell were the rust was .l ended up using sandblaster to get it all .my trailer was the same looked good until one use in the winter coating started flaking and the rust seemed to hid under until the coating chipped off . | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Sandblast. Epoxy prime. Rustoleum gloss black.
I had one sandblasted and powder coated. Rust has already popped up through cracks at a few rivet heads. Now I can't do anything about it because its hard to touch up powder coat. Rusty spots such as this on painted frames can easily be treated and touched up with a rattle can o Rustoleum.
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Powder coating in my area in my experience is not very good .corrosion gets under and the powder coat and flakes off . When I sanded my rims that were powder coated they were very difficult to sand and spots that were still shinny looking chipped off and there was rust underneath ,making it difficult to tell were the rust was .l ended up using sandblaster to get it all .my trailer was the same looked good until one use in the winter coating started flaking and the rust seemed to hid under until the coating chipped off . Did I mention that I live in So Cal? Sorry. | | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | Yea the powder coat in your area probably lasts a lot longer than here . Today I look outside and see snowbanks you have to be careful backing out of the driveway because there blocking your view. | | | | | Joined: Jan 2020 Posts: 24 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 24 | After sandblasting, I applied epoxy primer and then industrial enamel black. | | |
