Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Donf, Otto Skorzeny, Youngin' Tut 59, TooMany2count, 1 invisible), 127 guests, and 5 robots.
Topics128,277
Posts1,058,441
Members48,490
#134421 05/27/2006 6:59 PM
Ok I seached it may be here but I can't find it. I have a 61 apache with stock torsion bar IFS. I am happy with ride quality but would like disc breaks and power steering without a second mortgage. I have a friend that will sell me a coplete 83 1/2 front Ifs and power steering box, cheap. Has anyone done this swap on a 60-62 1/2 ton. Any better ideas? Thanks
#134422 05/28/2006 5:23 AM
This is a relatively easy swap on a '63 or later, but I don't think it is possible to swap the crossmember to your '61. The frame is quite a bit different.
I don't know if its possible to swap just the spindles, but you might look into doing it that way.
#134423 05/28/2006 2:41 PM
Thanks OldSub
#134424 05/29/2006 1:28 AM
Z
Z Offline
it is possible.some over at chevytalk have done it.
#134425 05/29/2006 1:43 AM
Zenish can you give us a link to a thread at chevytalk? I'd like to read about how it was done.
#134426 05/29/2006 4:34 AM
Quote
Ironic that this question was posted because I'm thinking of swapping out the front end on my son's '60 Burb. But my question is if the '63-'66 front end will interchange with the '60 Burb??
BTW OldSub, here's the link from ChevyTalk.
#134427 05/29/2006 5:24 AM
Seon that thread is swapping '72 stuff onto a '65. I know the '60-'62 is significantly different than the '63 to '87 design.
But I don't know how different. Anyone know if the ball joints are the same?
#134428 05/29/2006 5:10 PM
Chevy duty at www.chevyduty.com has a disc brake conversion kit available part # 71-976D6 cost $699.95...not the cheapest thing out there but a nice kit w/new spindles hose calipers bearings ect...also booster kit available part # 71-909 $349.95...not a lot of money but enough to make you cringe...pevinetrans...p.s. thi is for 60-62 trucks
#134429 05/30/2006 1:18 AM
The balljoints are different, the upper is the same as 3/4 ton to 1970 but only '60-'62 are the same on 1/2 ton. The lower is completely different due to the different control arm used
for the tortion bars.
Bill Burmeister
#134430 05/30/2006 5:54 AM
The kit im refering to that is made by chevy duty is made specifically for the 60-62 models
#134431 05/31/2006 11:44 PM
Thanks for all your input.
