7 members (55shaker, Shade Baby, Bill Hanlon, Jon G, 78buckshot, TrknGMC, 1 invisible),
109
Mod | | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | Ok I seached it may be here but I can't find it. I have a 61 apache with stock torsion bar IFS. I am happy with ride quality but would like disc breaks and power steering without a second mortgage. I have a friend that will sell me a coplete 83 1/2 front Ifs and power steering box, cheap. Has anyone done this swap on a 60-62 1/2 ton. Any better ideas? Thanks | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | This is a relatively easy swap on a '63 or later, but I don't think it is possible to swap the crossmember to your '61. The frame is quite a bit different.
I don't know if its possible to swap just the spindles, but you might look into doing it that way.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | it is possible.some over at chevytalk have done it. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Zenish can you give us a link to a thread at chevytalk? I'd like to read about how it was done.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Originally posted by OldSub: Zenish can you give us a link to a thread at chevytalk? I'd like to read about how it was done. Ironic that this question was posted because I'm thinking of swapping out the front end on my son's '60 Burb. But my question is if the '63-'66 front end will interchange with the '60 Burb?? BTW OldSub, here's the link from ChevyTalk. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Seon that thread is swapping '72 stuff onto a '65. I know the '60-'62 is significantly different than the '63 to '87 design.
But I don't know how different. Anyone know if the ball joints are the same?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2006 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 28 | Chevy duty at www.chevyduty.com has a disc brake conversion kit available part # 71-976D6 cost $699.95...not the cheapest thing out there but a nice kit w/new spindles hose calipers bearings ect...also booster kit available part # 71-909 $349.95...not a lot of money but enough to make you cringe...pevinetrans...p.s. thi is for 60-62 trucks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The balljoints are different, the upper is the same as 3/4 ton to 1970 but only '60-'62 are the same on 1/2 ton. The lower is completely different due to the different control arm used for the tortion bars.
Bill Burmeister | | | | | Joined: Apr 2006 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 28 | The kit im refering to that is made by chevy duty is made specifically for the 60-62 models | | | | | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | Thanks for all your input. | | |
