4 members (SNOYL, Paul_WNC, 78buckshot, Phak1), 58 guests, and 6 robots.
Topics128,012
Posts1,055,320
Members48,419
#1343976 01/28/2020 4:48 AM
8
8 Offline
The odometer in the 51 quit working. The plastic worm gear has broken. Does anyone know if the odometer from a 90 mph speedo will work in the older 80 mph speedometer? Thanks for the help!
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
My vote is that they will but wait for someone who knows for sure.
......I also found out, and have seen them, that some years ago the speedo's in some LaFrance fire trucks are the same as the AD gauges just in case you know were some old fire engines are sitting.....and they will have less wear on them.
8
8 Offline
I figure they will, too. But, I don't want to assume.
Thanks for the tip on the LaFrance fire trucks. I don't have access to one right now, but you never know what might pop up.
-Tim
Riding in the Passing Lane
All the old cable driven odometers are figured 1,000 revs per mile.
1972 Chevy c10 Cheyenne Super
You could probably swap out the little gears and keep the original parts that show. Like George said above, they all are built for the same revolution count.
2 Offline
okay i'm curious
which gear is "plastic worm gear"?
i've only taken apart about 4 speedometers to date ranging from 1950-53 years, both 0-80 and 0-90 type and that recent special 0-140 KPH metric speedo.
All the gears and worms are metal up to the first odometer counter.
Input shaft worm (steel) -> first gear to worm shaft (steel) -> second gear to worm shaft (steel) -> idler gear (metal, maybe brass) -> 1/10 ths wheel on odometer (odo is plastic).
maybe a photo would help
thanks
8
8 Offline
That was my mistake. I haven't looked at the setup for a while, and I remembered it wrong. It is the plastic gear on the tenths wheel of the odometer that is pretty well stripped. I'm sorry for the confusion.
-Tim
2 Offline
No problem we all forget things yeah
I’m pretty sure some places sell the whole odometer
So that sounds like what you need
Maybe it was chevs of the 40s that had it at one time
Else there should be many in the wrecking yards but you will need to put new number stickers on most.
I counted 14 teeth on the one I have on hand
Don’t know if that’s universal
-s
8
8 Offline
If anyone else is interested, Jim Carter offers the odometer by itself. They make no distinction between 80 and 90 mph speedos.
-Tim
