2 members (baldeagle, CuzzFuzz),
27
0
Mod | | | Forums66 Topics128,003 Posts1,055,245 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | I put a 1958 , 235 engine in my 49 1/2 using the 216 bell housing and flywheel, What do I use for timing ? The bb or the triangle. When installing the distributor . Thank you ! | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | The engine will start if you time the distributor to the BB, but you might have to tinker with things to get the best performance. There were several changes made in flywheel markings from the 216 to various years of 235. The best approach is to find the actual TDC point using the "positive stop" method, marking that spot, and using a delay-flash timing light to monitor what the actual advance is where the engine runs best. The BB is just a place to start with. Jerry
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | X2. Since the 216 era fuel was much lower octane than today, factory timing marks will likely be far too retarded for ideal performance. Once you get it started & warmed up, adjust to the fastest & smoothest idle, lock it down and readjust the idle. I time my '38 and '53 by ear. I got a lot of extra pep out of the '53 by doing that. If I'm wrong in my assessment I'm sure Jerry will let me know.
