0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 32 | 3 of the 4 spring hangers on the back of my Chevy 1.5 ton are worn/whopped out.
My first thought is to figure out something that would cross-over because this design went on forever, but can they be refurbished the original with new bushings? Cheaper to just make something else work? What is the best avenue of attack for this?
Thanks much. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Depends on the year of the 1.5T. ??????????
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2019 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 32 | How did that information get deleted? LOL It's a 1930. | | | | | Joined: May 2009 Posts: 135 'Bolter | | 'Bolter Joined: May 2009 Posts: 135 | Charlie, See if you can find the number FZ-2548-50 cast into one of the hangers. If so, the chevy parts catalog confirms that all four hangers are alike and that they fit ALL sizes of Chevys for 1929-1932. This seems odd to me but I am just reporting what the catalog says. The actual Chevy part number is 356935. You could set up an eBay search for the part number and also look for a frame left over from a rod project. Let me know if I can help. Mike in Missouri direct email [email protected]
| | | | | Joined: Jul 2019 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 32 | Charlie, See if you can find the number FZ-2548-50 cast into one of the hangers. If so, the chevy parts catalog confirms that all four hangers are alike and that they fit ALL sizes of Chevys for 1929-1932. This seems odd to me but I am just reporting what the catalog says. The actual Chevy part number is 356935. You could set up an eBay search for the part number and also look for a frame left over from a rod project. Let me know if I can help. Mike in Missouri direct email [email protected]Thanks Mike. Sure appreciate that. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | On a 1928 dump truck we worked on we welded a solid plug into the worn out hole and then bored the plug to the correct size.
Evan
| | | | | Joined: Jul 2019 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 32 | On a 1928 dump truck we worked on we welded a solid plug into the worn out hole and then bored the plug to the correct size. Yeah I thought about that as well. And this is how we gather campfire stories! Thanks Coilover | | |
