6 members (klhansen, Tom McGrath, Shaffer's1950, David Bush, Hotrod Lincoln, JW51), 82 guests, and 0 robots.
Topics128,051
Posts1,055,735
#133926 02/28/2006 9:27 PM
Any thoughts on what S10 fraim is best under an old chevy body. with a big inline? with a smallblock 8?
"It ain't a truck if you can't hose out the cab."
#133927 02/28/2006 10:33 PM
I had a couple of 1980s s-10 blazers, and they had a pretty darn beefy frame. I also know a couple of people who through 350s in em and the frame didnt bend or tweak in the least.
My 1953 Chevrolet
1947.1 Gallery
#133928 03/01/2006 12:35 AM
Most use the 80's long cab s-10. the only problem is that the wheelbase is alittle to long and will need to shortened. Also the rearend is to narrow and will need to be swapped for one form a s-blazer or one of your choice. For body mounts you can go to www.ad-engineering.com . I personlly just install a sub frame from a 60's camaro or nova. Either way you will have your work cut out for you.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#133929 03/01/2006 4:22 PM
Just bought an S-10 to go under a 53 pickup. The regular cab long box are the same wheelbase as the 53.
I'll let you know how it goes.
#133930 03/04/2006 2:58 AM
Apprentice
Apprentice
I am in the process of doing that swap right now. I dont think it is that bad just takes up a lot of space in the garage , parts every where. I used an 82 S10 long bed pickup. I thought I was going to have to shorten the frame a little but it turns out it fits real nice. Good luck..Dave B
#133931 03/30/2006 7:54 PM
those stock s-10 rearends are pretty beefy to,or they suprised me anyway,I had a 10 with a 355ci and built turbo 350 in it,ran out of money for a rear so I just lincoln locked the stock 342 rear and put 8" MT's on it and run the crap out of it,the motor went before the rear end did,I would have lost money on that,it was'nt a hp monster but wuold turn consistant 13.50's at the track,those s-10's are fun to play with.
1949 Styleline Special
1972 K5 Blazer
#133932 04/01/2006 2:32 PM
I'm not sure exactly which body you have, but I'll mention this anyway. If you use a 2WD S10 donor, you might need some outward offset wheels or a rear end from a 4wd/AWD S10, as they are 4 inches wider than the 2WD rear. I used the AWD rear on my 46 panel. The 2WD rear rbbed the inboard side of the tires when using the factory S10 2WD steel rims.
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
