| | | Forums66 Topics128,266 Posts1,058,369 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Any thoughts on what S10 fraim is best under an old chevy body. with a big inline? with a smallblock 8?
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I had a couple of 1980s s-10 blazers, and they had a pretty darn beefy frame. I also know a couple of people who through 350s in em and the frame didnt bend or tweak in the least. | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Most use the 80's long cab s-10. the only problem is that the wheelbase is alittle to long and will need to shortened. Also the rearend is to narrow and will need to be swapped for one form a s-blazer or one of your choice. For body mounts you can go to www.ad-engineering.com . I personlly just install a sub frame from a 60's camaro or nova. Either way you will have your work cut out for you. | | | | | Joined: Jan 2005 Posts: 164 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 164 | Just bought an S-10 to go under a 53 pickup. The regular cab long box are the same wheelbase as the 53.
I'll let you know how it goes. | | | | | Joined: Nov 2005 Posts: 19 Apprentice | | Apprentice Joined: Nov 2005 Posts: 19 | I am in the process of doing that swap right now. I dont think it is that bad just takes up a lot of space in the garage , parts every where. I used an 82 S10 long bed pickup. I thought I was going to have to shorten the frame a little but it turns out it fits real nice. Good luck..Dave B | | | | | Joined: Dec 2005 Posts: 112 Member | | Member Joined: Dec 2005 Posts: 112 | those stock s-10 rearends are pretty beefy to,or they suprised me anyway,I had a 10 with a 355ci and built turbo 350 in it,ran out of money for a rear so I just lincoln locked the stock 342 rear and put 8" MT's on it and run the crap out of it,the motor went before the rear end did,I would have lost money on that,it was'nt a hp monster but wuold turn consistant 13.50's at the track,those s-10's are fun to play with.
1949 Styleline Special 1972 K5 Blazer
| | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | I'm not sure exactly which body you have, but I'll mention this anyway. If you use a 2WD S10 donor, you might need some outward offset wheels or a rear end from a 4wd/AWD S10, as they are 4 inches wider than the 2WD rear. I used the AWD rear on my 46 panel. The 2WD rear rbbed the inboard side of the tires when using the factory S10 2WD steel rims. | | |
