10 members (JW51, Woodcmiami, dt235sd, MickeyP, Gdads51, HandyAndy, k2handyman, chevy51truck, Otto Skorzeny, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,699
Hi folks. I know there's a topic being discussed about moving the steering box to accomodate a v8, but I'd like to find a manual steering box I can mount to my tilt column. Trouble is, to keep my drag link and stock suspension I need a reverse rotation steering box. You know, when you turn right the pitman arm moves toward the firewall. I'd rather keep my manual steering (I like it that way)and all of my newly rebuilt suspension. And I know there's a power steering kit available that mounts the box ahead of the axle.
I know someone out there has HAD to have found a reverse rotation steering box to hook up to their tilt column with a rag joint. I'd searched and found some references to possible toyota or dodge boxes, but nothing definite.
Has anyone done this successfully with a reverse rotation box?
Thank you,
Tom
50-3600-Guy
oops ... I forgot to mention I have a 1950 3600 Chevy pickup.
Thanks for any suggestions ...
Tom
50-3600-Guy
I've seen pictures of a 70s Chebby truck box mounted forward of the axle, on the outside of the frame rail.
1954 GMC De Luxe COE
Z
Z Offline
im not sure what you are asking,but a sixties c10 has the steering box mounted on the outside of the frame in front.
Junior Member
Junior Member
67-76 BMW 2002 Are reversr rotation and are popular to use for cowl steering in modifieds and roadsters. The also are fairly cheap. 50 to 125 bucks Jay
Life expands or contracts in direct proprtion to your courage
I.I.# 4754
Thanks for the replies folks. And thanks Jimmy 6, I'll check into the BMW box. If anyone else has had success with a reverse rotation steering box please chime in, I'd very much like to know about it.
Thanks again all!
Tom
50-3600-Guy
Is your stock steering box trashed? If not,Maybe you could cut the tube down at the bottom and use a sealed bearing just like you'd do to your column if you wanted to use a new steering box with your original column.Then install your u-joint and connect your tilt column to it with a shaft and another u-joint.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Speed - That's an idea I hadn't really considered. My old box is still in good condition. I would still have to spacer it out away from the frame a couple inches. I do vaguely remember reading somewhere either on this board or elsewhere on the net where someone did this and told exactly how they did it. I'll have to do a search to see if I can find it. Especially the part about the bearing used after cutting off the column.
Thanks for the idea ... it's a good one.
Tom
50-3600-Guy
