1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | Hi folks. I know there's a topic being discussed about moving the steering box to accomodate a v8, but I'd like to find a manual steering box I can mount to my tilt column. Trouble is, to keep my drag link and stock suspension I need a reverse rotation steering box. You know, when you turn right the pitman arm moves toward the firewall. I'd rather keep my manual steering (I like it that way)and all of my newly rebuilt suspension. And I know there's a power steering kit available that mounts the box ahead of the axle. I know someone out there has HAD to have found a reverse rotation steering box to hook up to their tilt column with a rag joint. I'd searched and found some references to possible toyota or dodge boxes, but nothing definite. Has anyone done this successfully with a reverse rotation box? Thank you, Tom 50-3600-Guy | | | | | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | oops ... I forgot to mention I have a 1950 3600 Chevy pickup. Thanks for any suggestions ... Tom 50-3600-Guy | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I've seen pictures of a 70s Chebby truck box mounted forward of the axle, on the outside of the frame rail. | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | im not sure what you are asking,but a sixties c10 has the steering box mounted on the outside of the frame in front. | | | | | Joined: Dec 2005 Posts: 11 Junior Member | | Junior Member Joined: Dec 2005 Posts: 11 | 67-76 BMW 2002 Are reversr rotation and are popular to use for cowl steering in modifieds and roadsters. The also are fairly cheap. 50 to 125 bucks Jay
Life expands or contracts in direct proprtion to your courage
I.I.# 4754
| | | | | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | Thanks for the replies folks. And thanks Jimmy 6, I'll check into the BMW box. If anyone else has had success with a reverse rotation steering box please chime in, I'd very much like to know about it. Thanks again all! Tom 50-3600-Guy | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Is your stock steering box trashed? If not,Maybe you could cut the tube down at the bottom and use a sealed bearing just like you'd do to your column if you wanted to use a new steering box with your original column.Then install your u-joint and connect your tilt column to it with a shaft and another u-joint. Speed | | | | | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | Speed - That's an idea I hadn't really considered. My old box is still in good condition. I would still have to spacer it out away from the frame a couple inches. I do vaguely remember reading somewhere either on this board or elsewhere on the net where someone did this and told exactly how they did it. I'll have to do a search to see if I can find it. Especially the part about the bearing used after cutting off the column. Thanks for the idea ... it's a good one. Tom 50-3600-Guy | | |
