5 members (2-Ton, Ponchogl, 32Fordpuchoptop, dt235sd, 1 invisible), 102 guests, and 1 robot.
Topics128,049
Posts1,055,674
#1338760 12/23/2019 12:55 AM
Hello Bolters,
I have two different jack handles. I am wondering which one should be correct with my 1950 chevy 3100.
I have included pictures.
One is a "2" piece and the other a "3" piece.
Both come out to about the same length.
Any information would be great. I did a search but I could not locate anything on the different handles.
Todd
1950 Chevy 3100
All of mine are 2 pc. Never seen a 3pc. Homemade maybe?
Craig
It looks exactly like the 2 piece. It does not look homemade at all. Same pivot points, ect.
I'm a bit confused on them.
1950 Chevy 3100
From your pics, it looks like the 2 piece has a bit more leverage (more distance between the main shaft and the crank.) headscratch
I agree on leverage on the 2 piece.
Does anyone know when & what the 3 piece was used?
1950 Chevy 3100
Keep in mind that this jack system was in use across GM divisions for over 40 years. I would guess the three piece was adopted as a space saving/stowing measure. I agree that the two-piece is the correct version for your truck.
That 3 pc would fit perfectly in a '69 bug - JK nanner
Trying to help find any info online for the 3 pc and so far, zilch. Hmmmm
Craig
Your three piece is for a NAPCO modified 4x4 Chevrolet 3100. GM did not offer this but after market did. Taller jack with a three piece handle. Doc.
Doc,
Thank you for that Info!
Todd
1950 Chevy 3100
