Hello Bolters, I have two different jack handles. I am wondering which one should be correct with my 1950 chevy 3100. I have included pictures. One is a "2" piece and the other a "3" piece. Both come out to about the same length. Any information would be great. I did a search but I could not locate anything on the different handles. Todd
All of mine are 2 pc. Never seen a 3pc. Homemade maybe?
Craig
My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
From your pics, it looks like the 2 piece has a bit more leverage (more distance between the main shaft and the crank.)
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Keep in mind that this jack system was in use across GM divisions for over 40 years. I would guess the three piece was adopted as a space saving/stowing measure. I agree that the two-piece is the correct version for your truck.
Trying to help find any info online for the 3 pc and so far, zilch. Hmmmm
Craig
