| | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 6 Junior Member | | Junior Member Joined: Sep 2005 Posts: 6 | Only place to put the battery on my 49 Chevy 1/2 ton with small block is under bed,box welded to frame,want to install battery cut-off switch and remote battery terminals. I would prefer the switch/posts inside cab but don't want to drill holes bottom of cab. Inside of inner fender would work;more cable to route and secure,connections exposed to rain,ect. Battery removal will require taking some bed boards out. Would appreciate any ideas/input.Thanks. :confused: | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | On my '49, I put the battery in the stock location. The floor was a solid piece, so I made the bottom of the battery tray drop out. There are kits like these made since then. I also got some remote jumper terminals from Cole-Hersee. Also had a disconnect which I mounted in the frame, inside the passenger front fender. It was a bit of a reach. Whatever you do, the battery will need to be serviced / cleaned at regular intervals or the life of it will be shortened. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | if you go the extra expense of an optima gel battery the maintance is a lot less and the power is greater. it can even be installed upside down. ron btw somepeople install the battery in front on the fire wall where the heater motor sticks out using a newer battery carrier.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | when moving the battery a distance from the original location, make certain you use heaver than normal cables to overcome voltage loss. | | | | | Joined: Apr 2005 Posts: 113 Member | | Member Joined: Apr 2005 Posts: 113 | Is the battery mounted somewhere else besides beneath the floor in a 49? My battery is mounted underneath the passenger floor in my 48 and I can't see why a V-8 would interfere with the battery?
-Rich | | | | | Joined: Sep 2005 Posts: 6 Junior Member | | Junior Member Joined: Sep 2005 Posts: 6 | Hi,Wrench Fetcher,sub-frame of Firebird front end blocks part of standard pocket for battery; WE b OLD, I will check out the gel battery, have to buy new battery soon for this project; I can't picture it fitting on firewall but it might be good for remote battery box;I am making cables out of welding cable, it has four wires in it,and I am sodering on terminals,is this o.k? | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | I'm guessing you did an overlap and not a cut and weld?? Use battery cable, not welding cable. Battery cable comes in many sizes. [img] http://www.bunchobikes.com/1952suburban24.jpg[/img] | | |
