| | | Forums66 Topics128,091 Posts1,056,037 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | what company makes a quality lowering coil for my 61 1/2 ton. i want to go about three inches. i have my front torsion bars cranked down about that far, i could measure to se exactly what i need. i am more concerned about what company to buy them from than the size. what is a god one? i wouldn't mind of the ride was softened a little either!
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | you could bag it, not using a compressor for a reasonable price then manually adjust it to any height you want (simular to the old air shock days but gives a great ride) | | | | | Joined: Oct 2005 Posts: 2 Junior Member | | Junior Member Joined: Oct 2005 Posts: 2 | Peroformance Suspension Components (800)572-3768 Later Willis | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | LMC sells lowering springs, as does most aftermarket vendors. Send for some catalogs, I look in the advertising section of old truck magazines to find the different vendors. Scott | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Seems like Classic Performance has about the best prices and really good selection of everything needed for lowering. Some stuff that you can't find elsewhere. -David | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Mine came from Early Classic, great service fast shipping, little over $120. I used 3" in the rear looks good-takes the "tail up" look out.brian | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | Thanks all I am going to begin the hunt for the perfect rear springs...I will post what I end up buying.
