5 members (TooMany2count, Otto Skorzeny, MickeyP, Wally / Montana, Bill Hanlon), 101 guests, and 2 robots.
Topics128,052
Posts1,055,729
Anonymous
Unregistered
Anonymous
Unregistered
Had a productive weekend. Got the engine and transmission mated and installed into the frame.
http://www.picturetrail.com/gallery/view?p=999&gid=8156239&uid=2902753
1 Offline
what tranny x-member did you use?
2003 ford lightning
1959 chevy 36
Anonymous
Unregistered
Anonymous
Unregistered
Made my own out of 3 x 1 x 3/16 rectangular tubing. Check the chassis picture album out for a better pic of it.
Houston54 Looks great. Did you put in a recessed firewall to get the rear clearance? I'm in process of putting my 49 burb body to frame and hanging sheetmetal back together but is unpainted with a lot of body work to go. Looks like you'll be driving for the fall show & shines, Congrats,
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
Anonymous
Unregistered
Anonymous
Unregistered
49B,
Thanks but fall is a bit early to have color on it and have it back among the living. As you know, taking one apart is easy and cheap. The reassembly is the exact opposite.
As to the firewall I opted to not recess it as being 6'7" I figured if I did anything it would be to push it out for more leg room. Forget chopping the top too. It turns out that I have plenty of room in the engine bay. I can pull the distributor without pulling the eng and still have room in the front even using the Long Style water pump.
Right now we are doing a complete assembly to ensure all the parts fit and the systems work. Just added the dual diaphragm booster and master cylinder tonight. Hope to have the rear brake cables in this weekend so I can re-shoe the rear brakes.
Once we get that done it gets it final body work, sandable primer, blocking and then color.
Just trying to get a little done every week.
Very nice! What suspension kit izzat?
Mines the Dodge Dakota setup
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
I
I Offline
Lookin' good...
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
a very nice truck,, will be glad to see in on the road,heck , I might even drive to Houston to see it,,Fred
Redryder pix
My Hotrod
Houston, we DON'T have a problem! This looks like it's progressing great.
You're right about takin apart vs reassembly. Definitely not as easy as "reassembly is the reverse...etc." But yer doin a great job. Keep us posted.
Anonymous
Unregistered
Anonymous
Unregistered
Thanks all. Glad you like the pictures. I hope to mount the grill and front bumper this weekend.
I am at the point that I need your help. I need clear pictures of your SBC 4 barrel throttle linkage hookup so I can see where my brackets go.
I also need vacuum hose routing information. Will I need one of those vacuum balls for my installation? I have one out on the donor I can pull if it is needed.
If you have something that will help please send me a message.
I hate to ask but what is a vacuum ball? and where is it located,,,,,,,,,,,,,,,,,,,,,guess I had better stop while I am ahead...........Fred
Redryder pix
My Hotrod
Anonymous
Unregistered
Anonymous
Unregistered
Fred,
I did not know what it was until recently myself. On most "post stovebolt" vehicles many systems run off vacuum and a means to retain some vacuum when the engine was off was necessary so they developed vacuum cans or balls. On late 70's mid 80's GMs there is a round plastic "ball" mounted in the engine compartment to which several vacuum lines may be connected. If my description is dead wrong then please someone correct me but this is the jist of the matter as it was told to me.
The only things I see on my truck that will use vacuum are:
Transmission modular, Power brake booster, Distributor, and wiper motor (unless an electric option comes about).
1 Offline
newer cars/trucks have them too. my 03 f150 has two vacuum canisters behind the battery.
2003 ford lightning
1959 chevy 36
Anonymous
Unregistered
Anonymous
Unregistered
Was able to do some more to the truck this past weekend.
1. Installed power brake booster
2. Installed front grill
3. Shaved bumper bolts and installed bumper
Some new pics should come up here:
http://www.picturetrail.com/gallery/view?p=999&gid=8156239&uid=2902753&members=1
