3 members (FishinToms53, joe apple, Hotrod Lincoln), 81 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
#1327876 09/27/2019 12:46 AM
I've notice an uptick in the stolen cars and trucks in magazines I read. Some seem to be found easier because of a tracking device on the vehicle.
Questions: has any of you put one on your truck? How much do they cost. Do YOU track it? If you can track it how does one actually know where it is?
OK, guys, teach me something. I'm thinking of putting one on my pickup....my friend had his enclosed trailer stolen, out from under his shed,
recently and the questions above came up.
Moderator
Moderator
2 Offline
Good question Alvin!
But I can't see anyone stealing a Fire truck!
If it happens, I won't have to look too hard!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Alvin, Google LoJack. Other than the factory stuff like OnStar that is the only system I’m familiar with.🛠
Tuck an old Iphone under the dash, you would need to hot wire it to keep it charged tho. When someone steals your truck, use the "find my phone" app... of course, you might have to pay for the additional phone number.
Another quality post.
Real Trucks Rattle
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Thanks for the info. I'm looking at a couple of them...........I'm getting old. I figured once I bought one that was the end. Nooo, most of them want monthly fees!
Maybe I need to check out Radio Shack?........if any are still in business!
Again, thanks for the info and leading me in the right direction.
2 Offline
i also looked into security options a couple years ago, below are my 2¢
the iphone is a good idea... but there is a slightly better solution
use an old ipad mini with cellular data plan
the ipad is better than the iphone for tracking application in almost every way
- most carriers let you get a second data plan sim on your existing cell plan for as little as $10 or about that area
- it CANNOT make or receive cellular calls and text messages (it will do imessage but that's not important, don't enable imessage on the ipad when you set it up)
- it won't get called and spammed potentially interfering with it's intended use
- it has a much larger battery for when your truck battery runs low
- it has better reception due to larger antenna volume
- with an ipad you can take a peak whenever you feel like it to check all is well, you can't check in on your truck just for fun with a lojack
the down side is it's bigger to hide in the truck, but an ipad mini will fit well on top the glove box
lojack looks nice on the surface, but check coverage in your area first, you maybe disappointed, call your local police and ask about lojack before buying it
also lojack is not available in Canada anymore according to their website.
with lojack you also must let their tech install it in your precious truck, it is out of policy for you to do it yourself or be present while it's installed in it's secret location (often on top the glove box)
your ipad will work everywhere your chosen data plan works,
i suggest checking out TMobile for this application because they told me they would do unlimited data worldwide for $20 more on my cell plan.
-s
I know someone who tracks their teenage son's car with a LANDAIRSEA 54 from Amazon.com.
'53 3100 5-window
'57 Mercury Monterey 2-Door Sedan
Tim H
If you know how to secure your old truck the only way it could be stolen is with a tow truck or flat bed. There is no excuse for it getting driven away.
Can you track a trak phone? They are fairly cheap to use.
?? Chain it to something solid? Even that's not theftproof.
I locked a chain around one wheel of a cargo trailer and also to the tongue when I had to leave it on the road. My only thought was to make it harder for someone to drag it off. They still could but would smoke that one tire going down the road, or they'd have to have a different wheel to bolt on. The only real way is to make it hard enough for a determined thief to look for an easier target. JMHO.
Lock it or lose it! As the saying goes.. If it has wheels, weather they turn or not, I can take rather easily. See attached pic. If it dont have wheels then a rollback can load it up easily as well. Like previously stated, make it difficult or at least appear difficult. Thief's are usually lazy. JMHO from experience..
