8 members (tclederman, Hotrod Lincoln, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom, Otto Skorzeny),
179
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 106 | Any suggestions on keeping oil in the valve cover?
I’ve done two gaskets and it is still pouring out of the left front. What is everyone’s thought on removing the “blanket” that is inside the cover. I’m wondering if that isn’t directing the oil to one side. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That "blanket" was standard equipment.
Maybe one of our old-time truck-engine owners will comment on the purpose.
My guess is that it has something to do will lubricating the rocker-arm assembly and the valve stems? | | | | | Joined: Feb 2004 Posts: 29,784 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,784 | If it's a thick piece of felt, it's a holdover from the 4 cylinder days in the late 1920's when the rocker arms got lubed by squirting oi through some small holes in the valve cover with a hand-pump oil can to saturate the pad. Later 216's and newer engines didn't have that pad, so it probably won't hurt to remove it. A better idea would be to find where the valve cover is warped and straighten it. Remove the cover and invert it on a workbench and use something like a long carpenter's level and a feeler gauge to check for bowed spots that are failing to put pressure on the gasket. Repeatedly overtightening the valve cover hold down nuts can warp the valve cover and upset the sealing surface. Jerry
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | There is also a thin, steel strap that extends either side of hold down bolts that spread pressure, obviously won't work with center bolts.
Ec
| | | | | Joined: Sep 2013 Posts: 1,362 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,362 | What I did. It works on my truck but no guarantees on yours. As Jerry suggests straighten the flange, then apply a coat of your favorite high tack gasket product to the very clean and straight valve cover and stick your new (correct) gasket to the valve cover. I like KW Copper Coat for a high tack gasket sealer. Then smear Vaseline on the clean head area the gasket seals to. Then I used a gasket in a tube product on the headside of the gasket now firmly stuck to the valve cover. Did this Two years ago, removed a couple times since with no problem and no leaks on the now well seasoned gasket.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Aug 2019 Posts: 192 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 192 | I had the same problem with a brand new valve cover. Company sent me a replacement and it did the same. I took a small hammer and straight edge and tapped it in t h e places it wasn't sealing. Mind you this was on a new engine install. Just take your time and check it often with straight edge. Small piece of wood helps to rest it on when hammering it. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | It would be nice to have an extra loose head laying around to use as an "anvil" on a work bench to tin smith the valve cover into perfect shape. I did this for a 216 valve cover. It was so squashed down and bowed out on the sides that I could not have fixed it otherwise.
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Reality is valve cover and side covers leaked when the engine were new. Tuning the the cover, glueing the gasket and using a quality gasket helps.
I purchased an aluminum valve cover and used modern gasket cement with no gasket. No leaks..........
| | | | | Joined: Oct 2018 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2018 Posts: 112 | If none of the above solutions work for you. You could get your torch, and a brazing rod out, and just weld the cover to the head.  I've been plagued with those leaks from time to time. Even when I've already straightened out the cover(s) -- annoying as heck! All the best! Chris
'64 Chev C20 LWB stepside (Ol'Blue)
| | | | | Joined: Nov 1995 Posts: 5,720 62401 | | 62401 Joined: Nov 1995 Posts: 5,720 | I discovered a very simple (although somewhat expensive ...) fix for the leaking Stovebolt six .... Park a Detroit 6-71 next to it. Pretty soon, you won't even notice the leaks on the Stovebolt ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Oct 2018 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2018 Posts: 112 | Brilliant, John!  Quick! Get a patent out on it. Before someone else does.  Chris
| | | | | Joined: Feb 2004 Posts: 29,784 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,784 | When your Detroit (or stovebolt) quits leaking, pour some more oil in it- - - -it's empty! Jerry
| | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | Jerry, I have always just poured oil ON the Detroits, it'll soak in somewhere. Can we use a 6-92 or an 8-71 if we don't have a 6-71 at hand?
| | | | | Joined: Aug 2011 Posts: 22 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 22 | Detroit's don't leak, but, they do mark their territory, really well.
| | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | What is the difference between a leak and a seep?
| | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | What is the difference between a leak and a seep? My criteria is: A leak makes it to the ground. A seep just gathers dirt and dust.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Excellent  | | | | | Joined: Mar 2007 Posts: 3,386 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,386 | Master Sargent Halfmast (US Army PS Magazine) said : Class 1 - wet residue on surface : Class 2 - Droplets form on surface: Class 3 - Droplets form and fall from surface.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | What is the difference between a leak and a seep? Who owns the truck...if you own it, it seeps, if someone else owns it, it leaks... My old stepmother used to say the difference between homely and ugly was money. | | |
