3 members (Peggy M, TUTS 59, Maybellene), 175 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#1325320 09/08/2019 2:02 PM
Any suggestions on keeping oil in the valve cover?
I’ve done two gaskets and it is still pouring out of the left front. What is everyone’s thought on removing the “blanket” that is inside the cover. I’m wondering if that isn’t directing the oil to one side.
~Justin
1937 Chevy 1/2-ton
"Wylburr Clyde"
More pictures on Google
My Grandfather bought it new and Dad drove it through highschool. The 3rd & 4th generations put it back on the road on 8/8/2015!
That "blanket" was standard equipment.
Maybe one of our old-time truck-engine owners will comment on the purpose.
My guess is that it has something to do will lubricating the rocker-arm assembly and the valve stems?
If it's a thick piece of felt, it's a holdover from the 4 cylinder days in the late 1920's when the rocker arms got lubed by squirting oi through some small holes in the valve cover with a hand-pump oil can to saturate the pad. Later 216's and newer engines didn't have that pad, so it probably won't hurt to remove it. A better idea would be to find where the valve cover is warped and straighten it. Remove the cover and invert it on a workbench and use something like a long carpenter's level and a feeler gauge to check for bowed spots that are failing to put pressure on the gasket. Repeatedly overtightening the valve cover hold down nuts can warp the valve cover and upset the sealing surface.
' Offline
The Filling Station
sells a valve silencer pad .
https://www.fillingstation.com/shop/?year=All&vehtype=All&search=silencer&searchtype=FT
They were also made for V-8's
https://i.postimg.cc/7ZR50PRh/Chev-Silencer.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Crusing in the Passing Lane
There is also a thin, steel strap that extends either side of hold down bolts that spread pressure, obviously won't work with center bolts.
Ec
What I did. It works on my truck but no guarantees on yours. As Jerry suggests straighten the flange, then apply a coat of your favorite high tack gasket product to the very clean and straight valve cover and stick your new (correct) gasket to the valve cover. I like KW Copper Coat for a high tack gasket sealer. Then smear Vaseline on the clean head area the gasket seals to. Then I used a gasket in a tube product on the headside of the gasket now firmly stuck to the valve cover. Did this Two years ago, removed a couple times since with no problem and no leaks on the now well seasoned gasket.
RonR
1970 340 Duster
1964 CJ5
I had the same problem with a brand new valve cover. Company sent me a replacement and it did the same. I took a small hammer and straight edge and tapped it in t h e places it wasn't sealing. Mind you this was on a new engine install. Just take your time and check it often with straight edge. Small piece of wood helps to rest it on when hammering it.
1949 3100
Old Blue
It would be nice to have an extra loose head laying around to use as an "anvil" on a work bench to tin smith the valve cover into perfect shape. I did this for a 216 valve cover. It was so squashed down and bowed out on the sides that I could not have fixed it otherwise.
Reality is valve cover and side covers leaked when the engine were new.
Tuning the the cover, glueing the gasket and using a quality gasket helps.
I purchased an aluminum valve cover and used modern gasket cement with no gasket.
No leaks..........
If none of the above solutions work for you. You could get your torch, and a brazing rod out, and just weld the cover to the head. wink
I've been plagued with those leaks from time to time. Even when I've already straightened out the cover(s) -- annoying as heck!
All the best!
Chris
'64 Chev C20 LWB stepside (Ol'Blue)
62401
I discovered a very simple (although somewhat expensive ...) fix for the leaking Stovebolt six .... Park a Detroit 6-71 next to it. Pretty soon, you won't even notice the leaks on the Stovebolt ...
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Brilliant, John! smile
Quick! Get a patent out on it. Before someone else does. wink
Chris
When your Detroit (or stovebolt) quits leaking, pour some more oil in it- - - -it's empty!
7
7 Offline
Jerry, I have always just poured oil ON the Detroits, it'll soak in somewhere. Can we use a 6-92 or an 8-71 if we don't have a 6-71 at hand?
Detroit's don't leak, but, they do mark their territory, really well.
What is the difference between a leak and a seep?
Another quality post.
Real Trucks Rattle
My criteria is:
A leak makes it to the ground.
A seep just gathers dirt and dust.
Excellent thumbs_up
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
Master Sargent Halfmast (US Army PS Magazine) said : Class 1 - wet residue on surface : Class 2 - Droplets form on surface: Class 3 - Droplets form and fall from surface. grin
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Who owns the truck...if you own it, it seeps, if someone else owns it, it leaks...
My old stepmother used to say the difference between homely and ugly was money.
