0 members (), 116 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
Junior Member
Junior Member
iwas worried my tank hangs to low but yours look about the same. you can see mine on my communit webshots. community.webshot.com/user/rsteltz i have to put in the filler and cap ( on fender). coolcap from airride. yours looks good.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Junior Member
Junior Member
Seen your message in response to under bed tank. You put filler door in fender. Did you have to c-notch the frame and what gas tank did you use. Finally do you think same set up will work in my 1950 3100 ?????
Junior Member
Junior Member
putting mine through bed floor classic performance products version .using one of the billet gas doors here: http://www.allsalesmfg.com/ page 3 for PT crusier. i do not want to notch my frame.
yes the tank installs from the top with a c notch. the tank was not cheap from www.fatfenderedstreetrods.com arond 580.00with shipping. and the cap was 59.00 with another 59.00 for flanger it can be installed with out the flush flanger by surface mounting it. yes it will work on a 1950. ron
2017 Buick Encore
See more pix
1 Offline
I installed one of those plastic fuel cells under my bed, behind the rear axle. The bottom of the tank sits a few inches above the bottom of the rear axle. The tank is about 18" from the rear bumper. With the -6 lines and fittings, filter, and mounting brackets, it probably cost me about $300-350.
1957 Chevy Stepside
1993 GMC Sonoma
