7 members (dt235sd, RdsLessTaken, Gazz, Woodcmiami, Charles in CA, TexasA&M48Truck, BC59),
100
Mod | | | Forums66 Topics128,094 Posts1,056,483 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 14 Junior Member | | Junior Member Joined: Jan 2005 Posts: 14 | | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | iwas worried my tank hangs to low but yours look about the same. you can see mine on my communit webshots. community.webshot.com/user/rsteltz i have to put in the filler and cap ( on fender). coolcap from airride. yours looks good.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: May 2005 Posts: 9 Junior Member | | Junior Member Joined: May 2005 Posts: 9 | Seen your message in response to under bed tank. You put filler door in fender. Did you have to c-notch the frame and what gas tank did you use. Finally do you think same set up will work in my 1950 3100 ????? | | | | | Joined: Jan 2005 Posts: 14 Junior Member | | Junior Member Joined: Jan 2005 Posts: 14 | putting mine through bed floor classic performance products version .using one of the billet gas doors here: http://www.allsalesmfg.com/ page 3 for PT crusier. i do not want to notch my frame. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | yes the tank installs from the top with a c notch. the tank was not cheap from www.fatfenderedstreetrods.com arond 580.00with shipping. and the cap was 59.00 with another 59.00 for flanger it can be installed with out the flush flanger by surface mounting it. yes it will work on a 1950. ron
| | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | I installed one of those plastic fuel cells under my bed, behind the rear axle. The bottom of the tank sits a few inches above the bottom of the rear axle. The tank is about 18" from the rear bumper. With the -6 lines and fittings, filter, and mounting brackets, it probably cost me about $300-350.
1957 Chevy Stepside 1993 GMC Sonoma
