9 members (Jims46, Gdads51, 55shaker, jay d, Otto Skorzeny, Hotrod Lincoln, Youngin' Tut 59, 2 invisible),
84
Mod | | | Forums66 Topics128,288 Posts1,058,546 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 25 New Guy | | New Guy Joined: Oct 2012 Posts: 25 | I am trying to take the tank out of my 53 I removed the seat, took the straps off and I took the filler neck hardware off. I tried to wiggle the tank a little to make sure I had it all and the tank is not budging at all. Is there something else I am missing?
1953 Chevy 3600
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Is is stuck with 59 years of spilled coke, coffee, and who knows what? It sits on 4 asphaltic pads wiggle it back and forth it should come? | | | | | Joined: Oct 2012 Posts: 25 New Guy | | New Guy Joined: Oct 2012 Posts: 25 | The only thing I haven't unhooked yet was that fuel line under the truck I am gonna do that next.
1953 Chevy 3600
| | | | | Joined: Oct 2012 Posts: 25 New Guy | | New Guy Joined: Oct 2012 Posts: 25 | Got it. Brad you were exactly right!
1953 Chevy 3600
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | When you put it back if you can't find pads get some used mountain bike tires and cut them to fit. Work perfectly. | | | | | Joined: Oct 2012 Posts: 25 New Guy | | New Guy Joined: Oct 2012 Posts: 25 | When you put it back if you can't find pads get some used mountain bike tires and cut them to fit. Work perfectly. I'll keep that in mind
1953 Chevy 3600
| | | | | Joined: Jan 2002 Posts: 2,854 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,854 | Using old mountain bike tires? What a great idea, since I'm in the bicycle business.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | That's a great idea even if you are not in the bicycle business! It should ba added to the TECH TIPS section. | | | | | Joined: Feb 2019 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 40 | I'm about to put the gas tank back in my 3600 and can't remember how it was assembled. I'm going to buy straps but they appear like there is only one attachment place at the end of the tank bracket. From what I've read here, it seems like the other side sits on the inside rail of the frame. Is this correct? Classic Chevy parts https://www.classicparts.com/basket.aspAnother gas tank strap related part that is available but,. I can't tell how it might be mounted. https://www.classicdiscountparts.com/products.php?product=47%25252d54-Chevy-Truck-Gas-Tank-Brackets-with-Straps-(WTP)&gclid=Cj0KCQjwwb3rBRDrARIsALR3XeaZyhDAzCis_n9bQ15zTzlzta13uFVOVlXyY1oOTLl6GQFbjXJMfhQaApsVEALw_wcB
| | | | | Joined: May 2015 Posts: 11,279 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,279 | Another gas tank strap related part that is available but,. I can't tell how it might be mounted.
https://www.classicdiscountparts.com/products.php?product=47%25252d54-Chevy-Truck-Gas-Tank-Brackets-with-Straps-(WTP)&gclid=Cj0KCQjwwb3rBRDrARIsALR3XeaZyhDAzCis_n9bQ15zTzlzta13uFVOVlXyY1oOTLl6GQFbjXJMfhQaApsVEALw_wcB Your url posted for gas tank brackets is for mounting the tank inside the cab behind the seat. It welds to the floor behind the seat riser. The longer strap goes around the back of the tank and bolts to the shorter strap.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 1995 Posts: 5,762 24601 | | 24601 Joined: Nov 1995 Posts: 5,762 | Mountain bike tire pieces aren't too thick? I used some glass setting tape (strips of rubber for setting the window glass back inside the outer frames on the early AD door glass) I had left over and it worked great.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2019 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 40 | KlHansen, Thanks for clearing that up for me. Luckily mine is a stock inside the frame rails installation. Do you know how the tank is mounted this way? The mounting brackets only have one attachment hole and the straps appear to have only one point of attachment so, either the tank hangs just from these two holes (two mounting brackets) or also rest on the frame rails. I got this impression from the talk about using bike tube rubber as a cushion. I could find out by buying the straps and checking the fit but, I'm a little hesitant to layout 90 bucks for something I can easily fab. I was just wanting to get a clear understanding about how the stock tank was held in place. Thanks Joel
| | | | | Joined: May 2015 Posts: 11,279 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,279 | The Factory Assembly Manual shows brackets attached to the frame rail extending over the tank with the strap bolted to the bottom of the frame rail, extending under the tank and bolting with the threaded end to the inboard end of the brackets. It shows anti-squeak material glued to the inboard and outboard parts of the bracket where it contacts the tank. It's Section 8, Sheet 1.01 if you have the FAM.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 40 | I'm looking at sheet 1.01 3600 model very near to the front of the book but, don't see that good of detail. There must be another I'm not finding. | | | | | Joined: May 2015 Posts: 11,279 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,279 | I'm looking at sheet 1.01 3600 model very near to the front of the book but, don't see that good of detail. There must be another I'm not finding. Go back to Section 8, Sheet 1.01. Sounds like you're at Section 0, Sheet 1.01, which is the "index" page.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 40 | Kevin, Now I see how to use the assembly manual and, I can see how easy it will be to make my own straps. Thanks for your help. | | |
