8 members (Otto Skorzeny, 68ironhead, 3B, Jon G, Gdads51, NJC, 2 invisible), 104 guests, and 1 robot.
Topics128,130
Posts1,056,369
Members48,441
I have used the site helping me understand and fix things on my 1949 3100. I now have a 38 truck and am having issues with the battery. The knowledge on here is amazing. I hope someone can point me in the right direction. I look forward to being a part on the site.
1949 3100
Old Blue
I think you already found the electrical forum, but welcome here to the 'bolt.
Another quality post.
Real Trucks Rattle
Welcome to the Stovebolt madness. There is no cure! shake
GradyB, your in good hands here. We are family and you are now brother!!
I have some time this morning to add to my post. The 38 has been running good. Bought it in 2019. Had to pur new headliner in and repainted the various parts around it. Gas tank was removed and repaired as there are no replacements available. While changing oil have discovered she needed a valve cover gasket changed. While doing that discovered a slightly bent push rod. Now I'm working on that issue. This is a true original truck. Hopefully have it all together when the weather breaks to spring. Our collection has almost outgrown our garage. 38, 49, and 57 trucks, 31 chevy coupe, the wife just had to have, and a 79 dune buggy she also just had to have.
1949 3100
Old Blue
Love that '38! My Dad had one of those, but it was gone before I was old enough to drive it.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
I share in that sickness, lol! Beautiful trucks!
1953 Chevy 3100
   235, 3 spd. Mostly original so far
"The 1953 that Came Back"
Follow the build in the DITY Gallery
Just finished up on replacing the springs on the 49. Did front and rear. Now if the weather clears some I can take for test drive. Sure feels different when stepping on running boards. Doesn't sag down several inches when you get up on it! Even sets a little higher.
1949 3100
Old Blue
#1544112 04/15/2024 10:43 PM
Installed new springs over winter and went for first test drive today. What a difference!
1949 3100
Old Blue
Great looking truck right there. Really like the painted grille (altho not visible here).
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
O Online: Content
That looks like Mariner Blue, which was Ol' Roy's original color.
1950 Chevrolet 3100 (Ol' Roy)
What were the issues with the old springs in terms of what was visible?
Worn grooves where the springs rub together?
Broken spring?
Spring eye damaged from the pin wearing all the way through the bushing and into the spring eye?
The pins were wore thru bushings, 1 broke front spring, and 9 leafs on one side in front. It goes straight down road with not much wandering from side to side. Rides much stiffer now too. Doesn't roll to the side when going around corners.
1949 3100
Old Blue
Nice!
BC
1960 C60 pasture art
It's amazing how well a vehicle will ride when you replace steering and suspension components!! Trucks are looking good.
Real Trucks Rattle
O Online: Content
You got that right RR. I installed proper sized tires and rims and new shocks. Driving is a night and day difference. No steering work was required. I can let go of the wheel at 50 mph and it drives like its on rails.
