5 members (1955 1 Series, 55shaker, Otto Skorzeny, RLB, Shaffer's1950), 126 guests, and 3 robots.
Topics128,132
Posts1,056,391
Members48,441
I've got a '46 Panel and put a MII frontend under it. Well when I went to hook up the coulmn I found that the splined end of the rack was to close to the upright portion of the crossmember. I've talekd to all the manufacturers and the only thing anyone could come up with was to notch the crossmember. Has anyone one else run into this? If you have how did you fix it? Here are some pics of the problem.
Steering Shaft
Steering Shaft2
Steering Shaft3
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
I just installed a mustang11 on a 53 frame, it looks exactly like yours. I was thinking the same thing as, not enough space to install the shaft. We are not that far along to install the shaft yet , let me know how you solved the problem
Could you cut the splined section off and weld in a piece of pipe for an extention? If the pipe was a snug fit, everything would stay straight.
Just a thought,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
If you do any welding to correct your problem I would suggest that you drill, pin and plug weld as this is not an area for shoddy craftmanship, you do not want that sucker coming apart on you. Most of the time I see the pros notching the crossmembers before they mess with steering componants. Just my thoughts smile ......Dale
1939 GMC
1953 HD PANHEAD
1930 Chevy 3 window coupe
Quote
shoddy craftmanship
Who said anything about shoddy work? It can be done correctly, that's why I suggested beefing it up with a pipe sleeve. It would be more secure than the set screws on the joint thats to be installed,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
I am sorry if it came across as this method of work being shoddy, what I meant was to have someone with welding experience do this task and as extra strenght drill and pin and then plug weld the pin..........Dale
1939 GMC
1953 HD PANHEAD
I agree with your second post about the added security of a pin. You could also grind a flat spot into each of the shafts before adding the sleeve, then press the sleeve into the flat spot before you weld it. That way you would have a positive lock like a spline for added strength.
Just another idea,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
Interesting, I was thinking of using a MII on the next project.
Borgeson makes all kinds of couplers, shafts, joints and adapters, you will have to go to the catalog to get the full list.
http://www.borgeson.com
I would go with pinning, or set screws thinking about fixing or replacing in the future.
Please keep us posted.
Junior Member
Junior Member
All I did was notch out the frame and weld it closed with a piece of metal, to get a little more clearence. I didn't like that tight clearence either.
"Boop-Boop-a-doop"
