2 members (GrandpasJimmy, dunfire), 64 guests, and 4 robots.
Topics128,194
Posts1,057,263
Members48,466
Parting out a 1957 GMC dumptruck and while wrenching on it yesterday I was surprised to find a red vinyl pouch in the engine compartment that says it is for windshield washer fluid. Several questions here! Number one why is it a vinyl pouch and not some kind of solid reservoir, number two is there a fluid pump somewhere? Last where did it squirt onto the windshield? Thanks!
3B Offline
Hy Old Blue 1978, as far as I am aware there were no factory installed windshield washers. I think what you have found is part of an aftermarket kit, the pump was a rubber diaphragm that was mounted on the floor usually by the dimmer switch and it was operated by pumping with your foot. Nozzles and tubing to plumb them came with the kit along with instructions on where and how to install them, hope that helps.
7
7 Offline
My '57 Chevrolet two ton has factory washers, glass jar under the hood, rubber bulb with steel peddle, nozzles are incorporated in the wiper post. Maybe it was a LCF standard equipt.
If your pouch still has the tubing lines connected to it just follow them and they should be connected to the various other components.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
While Chevrolet was still using glass, GMC had gone to bags. This is a kit from 1954-55, it is not aftermarket (though different manufacturers were available) these were accessory items available at the dealer parts counter. They could be installed by the customer or dealer personnel.
https://www.flickr.com/photos/advance-design_parts_co/23812917635/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/23786818416/in/album-72157631868452754/
This is a very rare kit, I have never seen another as of yet.
As usual, nice post/image, Brad
As posted above, there was no GM/chevrolet factory installed windshield washer, but there was an accessory foot-operated windshield washer, bottle type (at least for 56/57/58 Chevrolet trucks).
If you don't know the real answer, it's best not to guess and say what you "think" is right. Please do not re-write history to fiction.
That bag is GMC Part Number 2233573 - Windshield Washer Reservoir
The red windshield fluid reservoir and associated pump were original equipment GMC that started in '54 and went through to '59.
If you doubt that, here are the GMC factory accessory pages for that system
https://photos.app.goo.gl/Y3486xzYXiJhi8c78
https://photos.app.goo.gl/U8Zq91gHzviTmQbu6
Not sure who the “real” comment is for but I have seen a lot of good truck guys alienated by similar posts. If somebody missed a key piece of info or content there are more constructive responses.
The OP’s question has been answered on several levels. I agree with Brad. Thread is done.
