7 members (Maybellene, FishinToms53, Bill Hanlon, Jon G, Shade Baby, Deltamac, papas52),
80
Mod | | | Forums66 Topics128,260 Posts1,058,103 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Help, I am new to this group. I am trying to get a Howard intake manifold set up on my 302 GMC. This manifold allows the use of 2, 3, or 5 stromberg 97 carburators. My question is has anybody run this manifold with 5 carbs? Do all carbs need a choke and idle circuit? Do the carbs need to be jetted down? My rough idea is to run with all 5 carbs. I would like to use the #2 and 4 carbs as primary, and the #1, 3, and 5 as secondary. My manifold is water-heated. I realize this may not be the best or easiest performance system out there, but it sure looks cool. It will be complimented by a Fenton exhaust, a hotter cam, hei ignition, and venolia 9 to 1 compression ratio pistons. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I have no idea on your set-up, but WOW. It'll probably run different every time you start it up. Make it a dual carb with three fake ones, it would be easier to set-up and still have your "look", Just a thought, Scott | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | That Howard intake is a rare one. You need to get over to Inliners.org and pose these questions. I've seen these intakes running on Inliners members GMCs but you need to find the man that own's one. Better yet, join Inliners Int. per the website and you'll then be able to contact some of our 'Tech Advisers', most of whom don't have the time for these forums. Also you should make our annual Central Cal picnic in Lodi, CA in Sept, and rub elbows with our many GMC inline fanatics. Also Turlock Swap Meet last weekend this month, row 'O' I believe you'll find a few guys with lots of inline GMC stuff. Best of luck | | | | | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | They are not to rare since they repo them,Patricks carrys them.
Gangster whites and straight pipes.....
