2 members (Hotrod Lincoln, homer52), 97 guests, and 1 robot.
Topics128,126
Posts1,056,355
Members48,441
Hi, I'm new here. I just picked up a 53 Chevy 6400 as a first project to work on with my boyfriend. We haven't settled on where we want to go with this project yet. Our first goal is to get it running (It needs a fuel pump)
'53 Chevy
Welcome to the Stovebolt madness. There is no cure! shake
welcome to the 'bolt.
Another quality post.
Real Trucks Rattle
Welcome to the Bolt. You'll love it here.
Welcome!
Nice looking Big Bolt you have there!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Looks like its in pretty good shape. That a 216?
The original 1953 engine in Large Marge was a low-pressure 235 that had an optional PCV set-up.
http://chevy.oldcarmanualproject.com/chevyresto/53113.htm
If you want to definitively ID your engine, post the codes shown on this page.
Right on. Thanks for the input. I pulled my 216 out and it looked literally identical to the one pictured. I have a 235 i need to go pick up but i have yet to see it (hasnt stopped me from buying accessories for it though) only thing i was curious about was the valve cover.. i was under the impression that the 235 had 4 side screw holes (screw holes hahaha) and the 216 had the 2 through the center. I guess ill wait and see what i get... im sure some of you guys would know alot more than me.
The early, low pressure (1941-1953) 235s had 2 center-top-bolts valve covers.
High pressure & low pressure 1953 235s had 2 center-top-bolts valve covers.
No high-pressure 235 was used a USA truck in 1953.
A high-pressure 235 was used in the 1953 Corvette (and, I think in Powerglide-equipped-235s) - the Blue Flame Six (painted a light blue color).
1954 and later 235s (and all 261s) had 4 side screws valve covers.
Awesome thanks. I have an old blue flame 2 center bolt valve cover i was hoping to use... if not ill probably sell it. You definitely know what ur talking about.
Thanks for the warm welcome and all the info (I can use all help I can get smile )The only numbers I was able to get to were the serial number: LEA 29i963 and the Head code: 3701887 GM-6. I added the pics to the album.
Big Bolt Forum Moderator
welcome to the site! Your truck looks to be in real good shape!
Mike
Head [casting] code: 3701887 = 1953 235 truck head (low pressure engine)
Engine Serial Number:
LEA = 1953 6000 series truck from Flint, MI engine
291963 - 1000 = 290963th engine out of that plant that year
(Your number/code = is quite large. Can you post a photo of that code?)
I don't know if the pic will show up. If not, I uploaded it to the album in my original post. Thanks for the help!
24601
Indeed -- Welcome! I see the Village Elders have formed the ceremonial detail, done the Stovebolt Dance of Welcome, sacrificed a Ford, etc, etc ...
It's good to discuss a course of action before diving in. We have a wealth of experience here so check in at the Big Bolts, Engine and Driveline forums and ask lots of question about what's related/involved in going in each of the directions you are thinking about. Check out our Tech Tips, too -- lots of info there. Some of it is actually useful. smile
In the meantime, we always recommend that the best way to start is just to get the truck safely driveable as is -- get it running reliably, make sure the brakes work correctly, check the tires and steering -- and just have a little fun with it this summer before making any big decisions. It may sound weird, but let the truck talk to you -- it will let you know what it wants. Some trucks are perfectly happy as is and don't want to be restored. Takes a little road time and a couple of oil changes before you can understand "truck" ... smile
You might want to begin by checking out this Tech Tip on starting an unknown engine for the first time
Its always a treat to see a "new" truck (to the site) that has *paint* visible on the firewall, engine, interior, etc and not rust and gunk and oil grime build up smile Looks like you have a very solid truck there and a good basis for whatever you want to do.
Thanks for stopping in -- we're glad you're here. Now learn something, apply it and then share what you've learned with someone else.
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
