1 members (stlcardinalsguy),
115
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | Ok; I installed my Carter/Webers over the past couple of weekends. I've finally got it running (somewhat). It's really cold-blooded. It wants to idle very fast when cold and chokes are engaged. It wants to idle too slow if I hit the gas to release the choke. Once everything warms up to operating temperature it seems to idle and accelerate ok.
I think my problem is with the hot water heat. It's not hot when the motor needs it to be hot.
Anyone try to run exhaust heat through the intake? How did you do it? Did you use an EGR valve? Will that work? It seems exhaust would get hot faster than the water. What do you guys/gals think?
Jerry | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | there have been some threads on the site over the last two months about this subject. i am in the process of installing one of langdons heat plates but hve not finished. the discussion was about water verses exhaust heat. langdons has a tech page about it. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | I'm using Tom's setup with water. That's what he recommends. It seems to me that the water doesn't warm fast enough. Why wouldn't an exhaust solution be better? | | | | | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | I have 2 of the Langdon carbs, his linkage, and his water manifold heat setup. It was basically a bolt on and use project. I wired both the chokes and they seem to work great. This is installed on a '62 261 with 848 head and Howard's cam in my '52 1/2 ton PU. I had one question before installation and Tom was very helpful.
Good luck with your project...it's worth it!
shoeless | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i hope the exhaust works as well or better. he says that you need a butterfly in the manifold to direct the heat but if i use copper it conduct heat very well, also the one drawback would be fouling from the carbon in the exhaust. i took out the plug in the manifold, the plug is hollow and there was a limited amount after almost a year of use. will post after i get mine finished. ron
| | | | | Joined: Apr 2005 Posts: 9 Junior Member | | Junior Member Joined: Apr 2005 Posts: 9 | hey guys i'm new to this forum and i am currently trying to hook up the water kit from langdon's onto my offenhauser manifold and today i got it all hooked up but it was leaking out of the manifold, i looked and there apears to be 2 plugs or somthing like that, can't really tell what they are but they are leaking from the bottom of the manifold, anyone know what this is or how to stop it from leaking? thanks | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | The offy 2x1 intakes with the alum plugs at each end on the bottom leak when water heat is used. These manifolds arre intended for exhaust heat. Ed Graham on this site has made some alum plugs to weld in so water heat can be used. Do a search.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | I put a layer of JB Weld epoxy over the plugs, or you can remove the plugs,apply the epoxy,reinstall plugs and re stake them in place. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | jerry, got my heat plate installed yesterday. works great, better throttle response, picked up 200 rpms at idle and better off the line at stop lights. mine is manifold heat. i am amazed at the results. ron. btw the test drive didn't go as well the shift linkages came loose and i drove across town in 2nd gear, fun at stop lights. the clutch let me know by the smell it didn't like the situation. at least i wasn't in fishers visiting my son and had to drive back to marion that way. ron
| | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | Ron,
Tell me more. Did you just run a tube from each header to the manifold heat block? What size tube? What diameter? What material (steel, copper, aluminum, etc.)? Did you put any kind of butterfly on one header to force the heat through the intake? Thanks.
Jerry | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i used a plate from langdons. no butterfly, seems the copper conducts the heat just fine more i think than the heat flow. they get hot quick. pictures late. ron
