4 members (Bill Hanlon, TooMany2count, 55shaker, Gdads51), 109 guests, and 2 robots.
Topics128,076
Posts1,056,280
Members48,441
#131252 03/07/2005 1:02 PM
Junior Member
Junior Member
G'day guys,
I have just purchased a 1 1/2 ton and was trying to get some information on the new front clip.
My question is can you have an independant front end with disc brakes and still retain the original 20" rims. what i am trying to achieve is the original look but with modern to new drive and handling... as good as you can have anyhow.
Is there a diff that i can have discs on and still retain the duels on the rear?
Thanks in advance
Jason. :p
46 1 1/2ton
#131253 03/07/2005 9:59 PM
you can put a newer chevy 1 ton runing gear under it and than put 19.5 wheels on it wich would be firly close to same size
or you could find some newer chevy 1 1/4 ton trucks that had that same old 10 and 5 cominatin so you could use orgnle wheel/tire
for my 46 I plan to use runnig gear out of
85 chevy C70 that has dics all around and narrow tham to fit my truck it also has 5.40 gears wich will make a littel better speed on hiway with the 270 gmc I am building for it
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
#131254 03/09/2005 9:15 AM
Junior Member
Junior Member
Thanks for the info, I am planning to run the new Gen 4 V8, with a 6 speed manual, probably with 3.08 diff maybe 3.55, as the truck is the same weight as the car that it will come from.
Will have power steer, air and cruise control, central locking and electric windows, but want the outside to look exactly the same as is.
Jason.
46 1 1/2ton
#131255 03/25/2005 3:42 PM
Socket Breaker
Socket Breaker
JBlanchard - Cool. Welcome to the 'Bolt. You may want to check out Timmer's post in the 'big bolt' section.... lots of '46 guys over there... the big bolt section is for you ton truck fellas.
smile
-W
