4 members (klhansen, Nick in Manitou, Lightholder's Dad, 1 invisible), 86 guests, and 2 robots.
Topics128,049
Posts1,055,679
#1311421 05/21/2019 5:32 PM
Is there a "standard formula" for measuring for shock length.
The two mounting points are 14 1/2" apart. I know the shock has to be able to extend/compress so basically my question is "how much". I don't think there will be a problem with extending, but more of how much the shock should be "out" for compression.
Hope you understand the question....I know many of you have probably been through this exercise.
I'm listening, so educate me!.
The simplest way to determine minimum shock length would be to actually measure it. Loop a piece of chain over the frame and under a floor jack, hook or bolt it together, and start cranking on the jack until something bottoms out- - - -suspension snubbers, etc. Then measure the distance between the upper and lower shock mounting points and add an inch or so "fudge factor" so there's no way for the shock to hit a mechanical limit. That's how we did it on the round track race cars where there were no factory specifications available. If your shop happens to have chain anchors built into the floor, or the suspension can be assembled without a spring in place, it's a lot simpler.
Actually all you need to do to measure actual suspension compression is to measure the space between the axle and the snubber. It's actually harder to determine how much to allow for shock extension, although you could do that buy jacking from the frame until the wheels come off the ground, and measure again between the axle and snubber. Subtract that from the measurement you took with the truck sitting on the wheels and that's the extension of the shock. As Jerry said, adding an inch or so in both directions would work.
I was told, 2/3 of the travel for compression, 1/3 for extension. As said above, axle stop should hit before shock bottoms out. http://www.monroe.com/downloads/install-instructions-guides/MonroeMountingLengthSpecifications.pdf
At the bottom ( page 77 ) are the mounting codes.
I measured my distance between mounting points with wheels off the ground and with wheels back on ground and called Monroe and they figured the correct shock for my 37 1/2 ton.
1937 GC
Thank you guys. Reading this brings rattles my brain back to many years ago that I thought I had forgotten.
Stovebolters to the rescue!!
