2 members (78buckshot, IHPWR),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 128 Shop Shark | | Shop Shark Joined: Feb 2019 Posts: 128 | So I have a silly question. How important are plug wires. I understand that they are CRITICAL for operation. But is there a noticeable difference between the $100 set and the $20 set? Not high performance or race application. Just in your everyday driving rig.
Hoka Hey! Spartan
1959 Chevy Spartan 100 "Battle Wagon" 2008 Buell Lightning "War Horse"
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | It's relative to what system you are using. Electronic and HEI systems require at least an 8mm carbon type wire. Wire core is not recommended for these systems. A good 7mm carbon type wire would work on your year truck with the stock points distributor. Probably $35 to $50 at most auto parts stores. Fred
| | | | | Joined: Feb 2019 Posts: 128 Shop Shark | | Shop Shark Joined: Feb 2019 Posts: 128 | Fred thanks. I have upgraded to HEI but the old plug wires don't fit on the cap. That's why I was wondering. I need to get a new set. Can you recommend some off summit?
Hoka Hey! Spartan
| | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | I would use AC Delco HEI wires, Summit should have them.
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | I don't have any preferences as there are a lot of good products out there. There are several variables however, depending what you are using for an exhaust system. The HEI ignition was introduced in 1975, they also used manifolds on small blocks that were located below the spark plugs. So the wires were on top of the engine over the rocker covers. Earlier rams horn manifolds typically had the plug wires under the manifolds which looks much cleaner in most applications.. Subsequently a stock set for a factory HEI wouldn't work well with rams horns. If you have rams horns and can find a set that is longer and specifically made for that set up, that would be my suggestion. If you have headers, you're on your own. Fred
| | | | | Joined: Feb 2019 Posts: 128 Shop Shark | | Shop Shark Joined: Feb 2019 Posts: 128 | Fred,
I just installed Headers so I'll figure it out.
Buckshot,
AC Delco sounds great to me!!
Kind of along the same lines- should I be using a different plug if I went to HEI?
Hoka Hey! Spartan
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | No need to change plugs but you will have to open the gap to .045
Hoka Hey! Spartan
