4 members (DBJ71SuperCustom, Stovebolt48, klhansen, Oswald), 124 guests, and 4 robots.
Topics128,196
Posts1,057,396
Members48,469
#1299115 02/15/2019 8:19 PM
I’m looking at buying a new gas pedal for my 49 Suburban as my original has no rubber left
There seems to be a wide range of prices for the repro pedals, does anyone know if they are all the same quality or are some to be avoided?
49 Suburban Project
The only thing I know is on my 49' is you have to get the one with a round hole on the back. I ordered a replacement pedal not knowing that I had to have one that was for a 49'. There's a difference in them. Hope this helps. The one that I have has a built up rubber on the back for rod that comes through the firewall and it has a press type fit to keep it in place.
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Fox Offline
Mike,
I purchased a repro pedal for my 1 ton AD (ball and socket type) and it didn’t fit worth blah. It was from LMC. I’ve found that on many reproduction parts it’s a crap shoot as to which parts are going to fit and which don’t. The pedal wouldn’t fit into the “push rod” when installed and when pivoted it would pop the ball out of the little socket on the back. I felt I didn’t want that happening when I was driving so I put it on my shelf and used the old one. My old one didn’t have rubber either but this is what I did. I got some nice heavy floor mat rubber, cut it to fit the pedal, predrilled some holes for (if I remember correctly) little 10-32 electrical bolts, and glued that sucker down with 3m spray adhesive. It looks good but isn’t original looking. If you can live without it perfectly original looking his may be an option.
https://photos.app.goo.gl/VtQVwTpsXddADEfy9
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Im sure you can use either type, ball-socket or cotter pin style just by using the push rod that matches. Have done that on one of my trucks.
1946 1/2-Ton Chevy
These are regulars on eBay for just a bit more then the reproductions. Here is an example item# 192429847340 (not mine).
You will find these by other manufacturers back then as well, difference is they fit.
https://www.flickr.com/photos/advance-design_parts_co/16404696303/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/23858678755/in/album-72157631868452754/
Sometimes you will find them in kits, this is war era conversion, pedal was used for many years (pinned type).
https://www.flickr.com/photos/advance-design_parts_co/31094895217/in/album-72157631868452754/
NOS pinned type.
https://www.flickr.com/photos/advance-design_parts_co/33252303518/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/33252303058/in/album-72157631868452754/
The issue with the ball and socket style pedals not staying put may not be due to the pedal itself. It may be due to a bent rod, or a non-stock position of the other end of the rod. Its all about geometry and motion. The section of the rod has a distinct curve to it so that it can pass through the hole in the toeboard freely. That curved section is not prone to bending, but the rest of it is, and sometimes they are bent to reach the non-stock connection at the carburetor or bellcrank.
(From Fox's description, he apparently got a hold of a bad new pedal.)
Carl
Fox Offline
I believe it was a bunk pedal. I tried a couple of my other parts pedals on the truck and they all worked fine, but not the reproduction. So I figured I’d keep the original.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
