4 members (Guitplayer, Hotrod Lincoln, Bill Hanlon, Gdads51), 106 guests, and 2 robots.
Topics128,109
Posts1,056,271
Members48,439
#129827 12/25/2004 8:03 PM
Hey guys can I carburate a 1991 350 Chevy motor out of a car. I have an intake manifold that is on the old 69 GMC that I want to put the motor in. Will it fit the 91 motor, or do I have to get a different intake from Summit to fit? Also will the motor mounts and everything work when mount this sucker in the 69? Thanks Shelly
#129828 12/26/2004 12:20 AM
If I remember right it will fit. But you have to do something to the center holes on the intake. I think you have to grind the holes a bit to get the bolts to go in.
#129829 12/26/2004 1:36 PM
The motor mounts and all will fit. The 91 motor is a one-piece rear main seal motor with center bolt valve covers. They're pretty close to being the same other than those differences (rear main seal and valve covers) and I think you can make an older manifold fit, but I've never tried it.
If it was me, I'd get a new manifold for the newer style heads.
The other option would be to keep the tbi...as long as you have the wiring harness and ECM. If not...well..then a new manifold isn't all that expensive. smile
#129830 12/26/2004 5:53 PM
Riding in the Passing Lane
I,ve read were you can grind out the center holes.
If it,s not an aluminum manifold I would get a new
one. You will have to use the fywheel on the 91
or get an 87 up flywheel. You wiil need a dist.
with vacuum advance. smile
1972 Chevy c10 Cheyenne Super
#129831 12/28/2004 4:48 AM
Thanks for the reply, Shelly
#129832 12/28/2004 10:16 PM
Hello ChevyShelly,
How is Ute? Is the water up or down there?
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#129833 12/31/2004 2:34 PM
The old lake is still holding pretty good level, had a lot of moisture this year.
#129834 12/31/2004 2:40 PM
Hey Phil, if your over hear in Logan, stop by and see my old trucks. Im at 502 Impala.
#129835 01/04/2005 12:34 AM
I used to frequent there. My brother-in-law had two jet skis that we would ride there. I even asked my father-in-law if I could have his daughter as my wife at Ute. I'll stop in next time I'm there.
Phil
#129836 01/04/2005 7:54 PM
Hey Shelly, How have you been. Is this engine going in your Blue truck? I still need to get over and take a look. Keep in touch!!
Ralph
rtlopez@shipleysystems.com
48 Chevy 3600 w/235
48 Chevy 3100 w/235:
You cant see the smoke on a dirt road.
#129837 01/09/2005 3:19 PM
Hey Ralph, no I thought I might put it in an old 69 4 wheel drive. Stop by some time
#129838 01/10/2005 2:49 AM
V
V Offline
Where is Logan?
Gangster whites and straight pipes.....
#129839 01/10/2005 1:53 PM
Its about 23 miles from Tucumcari, Old Route 66 runs through Tuc, I 40
#129840 01/11/2005 3:10 AM
Quote
Where is Tucumari? grin
#129841 01/11/2005 4:42 AM
Sub, as the crow flies that would be about 1100 miles southeast of you.
#129842 01/11/2005 7:42 PM
Hey,
I like seeing all these New Mexico Bolters. Welcome aboard OldCC. There are a few other stovebolters here in the county, but they are scared to death of a computer and don't get on-line much.
Ralph
48 Chevy 3600 w/235
