| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 52 | Hey guys can I carburate a 1991 350 Chevy motor out of a car. I have an intake manifold that is on the old 69 GMC that I want to put the motor in. Will it fit the 91 motor, or do I have to get a different intake from Summit to fit? Also will the motor mounts and everything work when mount this sucker in the 69? Thanks Shelly | | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | If I remember right it will fit. But you have to do something to the center holes on the intake. I think you have to grind the holes a bit to get the bolts to go in. | | | | | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | The motor mounts and all will fit. The 91 motor is a one-piece rear main seal motor with center bolt valve covers. They're pretty close to being the same other than those differences (rear main seal and valve covers) and I think you can make an older manifold fit, but I've never tried it. If it was me, I'd get a new manifold for the newer style heads. The other option would be to keep the tbi...as long as you have the wiring harness and ECM. If not...well..then a new manifold isn't all that expensive.  | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,ve read were you can grind out the center holes. If it,s not an aluminum manifold I would get a new one. You will have to use the fywheel on the 91 or get an 87 up flywheel. You wiil need a dist. with vacuum advance.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 52 | Thanks for the reply, Shelly | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | Hello ChevyShelly, How is Ute? Is the water up or down there?
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Nov 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 52 | The old lake is still holding pretty good level, had a lot of moisture this year. | | | | | Joined: Nov 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 52 | Hey Phil, if your over hear in Logan, stop by and see my old trucks. Im at 502 Impala. | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | I used to frequent there. My brother-in-law had two jet skis that we would ride there. I even asked my father-in-law if I could have his daughter as my wife at Ute. I'll stop in next time I'm there.
Phil
| | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Hey Shelly, How have you been. Is this engine going in your Blue truck? I still need to get over and take a look. Keep in touch!! Ralph | | | | | Joined: Nov 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 52 | Hey Ralph, no I thought I might put it in an old 69 4 wheel drive. Stop by some time | | | | | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 |
Gangster whites and straight pipes.....
| | | | | Joined: Nov 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 52 | Its about 23 miles from Tucumcari, Old Route 66 runs through Tuc, I 40 | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by ChevyShelly: Its about 23 miles from Tucumcari, Old Route 66 runs through Tuc, I 40 Where is Tucumari?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 52 | Sub, as the crow flies that would be about 1100 miles southeast of you. | | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Hey, I like seeing all these New Mexico Bolters. Welcome aboard OldCC. There are a few other stovebolters here in the county, but they are scared to death of a computer and don't get on-line much. Ralph | | |
