3 members (55shaker, 3B, 1 invisible),
144
Mod | | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Is it true that Fenton made exhaust headers for the 235 that had a heat riser that matched up to the intake manifold? Is this a desireable set up, if going to Fentons from the stock set up?
Thanks, John
~ One of many.
| | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | John and Peg, NTMK for Fenton, but the early 6 cylinder Corvettes had this set-up direct from the factory, integral heat and header.
This, as you can imagine is a very desirable piece. The last time I saw one for sale, and this is two years ago, was in the 4 bill range.
You can have one made out of your exhaust manifold by that guy out in Kansas (Kansas Kustoms?). See the inliners.org site for the email. regards, Cosmo.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Check it out. Don't know much about them. Headers w/ hear riser | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i just received my heat riser plate from langdons. but wouldn't that been a great thing on all of the fentons? still have to get bolts and i assume some kind of gasket. drove the 54/3100 yesterday and it almost ran. back fired and buck like a new stick shift driver behind the wheel. i blew a new muffler out a couple of weeks ago the same way, it was only 3 months old. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | I think that those are the originals,not the ones they make now.I bought a 50 Chev Deluxe a few years ago(gave to my father and he still has it)from the original owner and it had those same headers w/ heat riser.The Previous owner told me that he had them installed in 1961.
Gangster whites and straight pipes.....
| | | | | Joined: May 2004 Posts: 62 Member | | Member Joined: May 2004 Posts: 62 | Fenton Cast headers for the Ford 223 mated to the intake madifold like the stock Chevy intake/exhaust manifolds do!
Ever notice the 2 different gasket flanges on Fenton Chevy headers? One is for a donut gasket and the other side is flat.
The flat side is for a heat riser plate that would mount between the pipe and header flange.
47 Fleetmaster, Hotrod 6, 5 Speed 50 Sedan Delivery, 327, 5 Speed
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I bought a new set of Fentons in 1954, the came with a cast plate to bolt on the bottom of the intake and had two curved tubes and all fittings to connect to both headers (front and rear) for a heat source for the intake manifold. SIt worked great, the car held national m.p.h. and e.t. records in 1954 NHRA at Pomona, Ca. Only beat once by a cheater named Bruce Morgan. | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | fenton did in fact make headers with the exhaust heat riser. i've been seeing them on ebay. | | |
