6 members (Woodcmiami, Gdads51, Gib70, Peggy M, Cosmo, 1 invisible), 94 guests, and 2 robots.
Topics128,060
Posts1,055,840
Members48,427
#129513 03/06/2005 2:37 PM
Is it true that Fenton made exhaust headers for the 235 that had a heat riser that matched up to the intake manifold? Is this a desireable set up, if going to Fentons from the stock set up?
~ One of many.
#129514 03/06/2005 4:19 PM
ODSS President
ODSS President
C Online: Content
John and Peg, NTMK for Fenton, but the early 6 cylinder Corvettes had this set-up direct from the factory, integral heat and header.
This, as you can imagine is a very desirable piece. The last time I saw one for sale, and this is two years ago, was in the 4 bill range.
You can have one made out of your exhaust manifold by that guy out in Kansas (Kansas Kustoms?). See the inliners.org site for the email. regards, Cosmo.
~ Cosmo
1949 Chevy Half Ton
#129515 03/06/2005 4:19 PM
Check it out. Don't know much about them.
Headers w/ hear riser
#129516 03/06/2005 4:47 PM
i just received my heat riser plate from langdons. but wouldn't that been a great thing on all of the fentons? still have to get bolts and i assume some kind of gasket. drove the 54/3100 yesterday and it almost ran. back fired and buck like a new stick shift driver behind the wheel. i blew a new muffler out a couple of weeks ago the same way, it was only 3 months old. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#129517 03/06/2005 5:08 PM
V
V Offline
Quote
I think that those are the originals,not the ones they make now.I bought a 50 Chev Deluxe a few years ago(gave to my father and he still has it)from the original owner and it had those same headers w/ heat riser.The Previous owner told me that he had them installed in 1961.
Gangster whites and straight pipes.....
#129518 03/10/2005 6:21 AM
Fenton Cast headers for the Ford 223 mated to the intake madifold like the stock Chevy intake/exhaust manifolds do!
Ever notice the 2 different gasket flanges on Fenton Chevy headers? One is for a donut gasket and the other side is flat.
The flat side is for a heat riser plate that would mount between the pipe and header flange.
47 Fleetmaster, Hotrod 6, 5 Speed
50 Sedan Delivery, 327, 5 Speed
#129519 03/12/2005 5:17 PM
I bought a new set of Fentons in 1954, the came with a cast plate to bolt on the bottom of the intake and had two curved tubes and all fittings to connect to both headers (front and rear) for a heat source for the intake manifold. SIt worked great, the car held national m.p.h. and e.t. records in 1954 NHRA at Pomona, Ca. Only beat once by a cheater named Bruce Morgan.
#129520 03/21/2005 12:20 AM
fenton did in fact make headers with the exhaust heat riser. i've been seeing them on ebay.
Robert French MY3800FIRETRUCK
