3 members (Nick in Manitou, Sjm, 1 invisible),
88
Mod | | | Forums66 Topics128,264 Posts1,058,356 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | my brother and I are building a show truck and had this crazy idea to put a big block chevy in the back of a long bed 68 chevy, I figuerd it out that if I moved wheels back 8-12 inches and used a turbo 350 direct to a older corvett rear it would all fit behind the cab and I have most of the parts just take lot of labour. The main qestion is will it be able to handel freeway speeds without the engine above front supension or should I put lighter springs in front? | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Oh, heck. Why not a 572 crate motor? 620hp out of the box.
40 Chevy 1/2 ton
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Why not use the motorhome verion of the Toronado/Eldorado transaxle to allow leaving the wheelwells in the stock location?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | would ya be able to even license something like that for the freeway? :confused: hope ya got an engineer around to sign off on it!  could always move the gas tank under the hood for front weight, but don't tell the insurance company! Bill | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | A guy up here did up an S10 with a Toronado frontend in back | | | | | Joined: Apr 2005 Posts: 36 New Guy | | New Guy Joined: Apr 2005 Posts: 36 | you could do it but you will need to figure out a way to have enough weight under the hood or you will have no steerring ability. you could higher the rear and drop the front to put downward force but that still not enough
DustyG.
1952 Chevy 1.5 ton 1949 Gmc 2 ton flatbed Dump
| | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | A 454 powered "ford T buckett" is legal and this thing is will be hundred percent safer. worst case we could trailer it but would be way cool to be street legal! I think a NHRA approved fuel cell in front should be perfectly safe, also we hope to keep the engine right up aginst the cab and the raidator will still be up front, so it should be 50/50 front rear. could the motorhome version of the Toronado/Eldorado transaxle handle 425-500 horse power? | | | | | Joined: Dec 2003 Posts: 103 Member | | Member Joined: Dec 2003 Posts: 103 | The VW Beetle had a fuel tank up front/engine rear and was sold in the US after '68. So licensing your '68 shouldn't be a problem. I had a 57 bug in 1960 when going to high school in Alaska -- in the winter I carried about 50# of sand in the front. It handled great in the snow -- lots of fun. | | | | | Joined: Mar 2005 Posts: 49 Apprentice | | Apprentice Joined: Mar 2005 Posts: 49 | I seen a 70 model firebird convertable with a 454 big block mounted in the back seat at the Goodguys show. He added weight where the motor should be. | | | | | Joined: Oct 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 112 | Yep Olds tornado rear, corvair springs up front with stang rack and pinion steering, gotta measure front with engine and trans setting as is now, pull engine trans an redo springs so sets with new spring as if engine trans was there. Jbennett 40 burb | | | | | Joined: Oct 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 112 | Second thought , Porsche 924 transaxle, it will take 350 sb chevy tork. leave engine clutch up front, trans rear gear in rear. Could shorten whole unit so it fits eight foot bed, problem is shifting, could be figured out, jbennett 40 burb | | | | | Joined: Feb 2000 Posts: 5,265 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,265 | Any type of transmission will handle the 450 horse power as long as you don't put slicks under it. If it never hooks up, it won't break! If you are going to race it, then you need to do so real engineering. The longer wheel base will add weight to the front. You could also add lead weights from the dirt track cars. Joe | | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | thinking about putting engine in backwards trany forward, engineer some kind of gear box to trasnfere power back to rear end got a plan almost worked out using my mechanical engineers hand book to figure out what kind of gearing will be needed, that would also help with weight to the front becuse of trany in almost stock location, only backwerds | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | maybe you should go for this kinda thing! Bill | | |
