4 members (EchoBravoSierra, carbking, 2 invisible), 77 guests, and 2 robots.
Topics128,206
Posts1,057,438
Members48,471
Hello All,
Just made a 16+ hour non-stop run to ND and back to retrieve my new toy. Purchased this great old truck from an 85 year old gentalman that has owned it for over 40 years. Starts, runs and drives good. An old cheap driveway restoration in driver condition. 216, 4 speed with single speed rear. Going to service it from one end to the other and drive it locally for fun. Has two cracked windows, big dents were pounded out into small ones and a junk 50+ year old paint job that is scratched, chipped and I think it is perfect just like it is!
Hope you like it, I sure do.
Good luck on your projects everyone!
Tony
Red dot, center of chest ...
That truck is in amazing condition. It must have been cared for with great love. You have bought a real gem.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
That is just too cool.
Tony, great looking truck!
Welcome to the Bolt!
You probably don't remember me, but we have visited in the past regarding an old MM tractor. That truck will go great with the MM's and Twin Cities that you have.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Those 1938 models are great looking trucks. Congratulations on your new project!
Lots more pictures
Tony, I can only dream of ever having one like that. I'm happy for you and that is quite a find. Opportunities only come once in a life time like that. Glad you found it.
back yard wrench turner
Great truck you have there Tony. But I happen to really like '38 Chevy trucks from North Dakota!
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
So NICE! I was lucky enough to spend a few years in ND, ending Christmas '14. I so wanted to buy a 40' car hauler and load it with precious metal and bring it home. Trucks like yours are not everywhere but they are much more available than in the Lower 48 (as we used to say). I spent most of my time getting paid to ride and walk around in the boonies where you find ranches and farms that were no longer working and often abandoned. The Old folks died and the kids moved to town kind of thing. Most would't believe the museum like setting that are still out there.
Good Luck,
RonR
RonR
1970 340 Duster
1964 CJ5
I saw that listing for that nice truck. Glad someone picked it up that will enjoy it. Have fun!
What an incredible truck, it doesn't get any better than that !!
Troy
1963 Chevy C60
Big Red Chevy
1951 GMC 453 Series 3-Ton Army Truck
Big Bolt Forum Moderator
looks like a GREAT find!!
Mike
Working on the old bolt.
I have changed oil, greased entire chassis, checked all fluids and cleaned and set the ignition points. Left front brake was holding so I fixed that and took the truck out for a nice country cruise as the winter roads are good from recent thaw. Brakes are excellent now and it drives just fine.
I have learned that the engine and trans were pulled many years ago because under the grease and dirt I found chevy orange on engine block and trans. It runs quiet, perfectly smooth and there is no smoke so I am assuming it was rebuilt at that time.
Need to sort out some wiring issues to the head lights and brake light as they do not work. will continue to tinker clean over winter so I am ready for clean spring roads.
Stovebolt.com is a great find with many helpful folks, thanks for all the fun correspondence!
Tony
Hello all,
I have a question concerning lack of fuel. When this truck sits for a few days it will not start until you squirt a shot of gas in carb.
It starts and runs great until it has sat, then you must prime to get it going. Even pulling the choke on does not work after sitting.
It is original 216 with stock appearing fuel pump and carburetor. Any ideas?
Thanks Tony
Fuel is draining out of the float bowl. Common problem. 🛠
Fabulous find, congratulations on your new toy. Enjoy! And, drive it with that big smile I know you had on the way home.
The Check Valve in the fuel pump could be stuck open as well allowing the gas to siphon back into the tank.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
It is physically impossible for gas to leak back from the carb through the inlet. The inlet is above the fuel level in the carb.
Most of the time when you experience this it is because of a bad accelerator pump in the carb.
You may also want to be sure that the choke is closing completely.
My Blog
Nice, I have a 38 TD as well. though mine was in no where near that condition and still isn't.
