6 members (Otto Skorzeny, MikeE, Hotrod Lincoln, ShopRag, TooMany2count, J Lucas), 32 guests, and 2 robots.
Topics128,036
Posts1,055,450
Members48,422
#12897 03/11/2005 7:37 PM
Hi Everyone, I'm a new guy to this forum as well as Chevy trucks in general. I've only owned mopar pruducts up to this points. My first car was a "civilinized" police car that was 1980 Dodge St Regis. She had a 360 with a thermoquad carb on her. My second car was 1965 Plymouth Barracuda with the 273 v8 2b. carb. I'm now the proud owner of my current project a 1960 k10.
Now over the years I've become somewhat acquainted with the pro's and con's of many of the mopar engines in regards to performance, efficiency, reliability, etc. However, I'm starting out totally new in regards to Chevy's.
My Dad had the truck before me and pulled the 235 out of it and put in a 400 v8.
She has the standard corporate 4-11 diffs. She has HUGE 35x12.5 tires. Her top speed is about 60 miles per hour, but that doesn't matter to me as her purpose will be what she was originally manufactured to be.
Now to my loaded question. I say it's loaded because as I read the forums I see a lot of guys who love the stock 6's that came with the trucks and then there are those that love the v8's, but here we go.
What is the best Chevy engine to put in this truck for the purposes of hauling, torque, pulling, and general all around oomph? What is the history in regards to reliability of various Chevy engines? I hear alot about the 350. What are your thoughts?
[img]http://www.ThePixPlace.com/is17880.jpg[/img]
#12898 03/11/2005 8:34 PM
H Online: Content
If you can keep it cool, (and that's a big IF) your 400 smallblock will out-torque a 350. The 400 has a 3 3/4" stroke, as opposed to the 350's 3.48" stroke. It also has a 4 1/8" bore, bigger than the 350's 4" bore. Be sure to use the biggest radiator that will fit, and keep it clean. A 7-blade flex fan and a good shroud should be included, and if you're running an automatic transmission, use a big cooler on it, also. The 400's worst enemy is heat that cracks cylinder heads and causes pistons to tighten up and score.
#12899 03/11/2005 9:18 PM
That new 572 big block crate motor is probably going to provide the most power and all-around torque.
The 388 stroker small block might be the easier and more versitile swap.
You probably want to think through what you're willing to spend on the motor, and how much you'll have available to replace broken drive train parts.
If your requirements statement had been cheap and reliable I'd have suggested the 350.
#12900 03/11/2005 9:39 PM
I have had good luck with the 350s,both my 55 and 72 pickups have late 70s 350 truck motors,4 bolt mains.Just my 2 cents worth.
#12901 03/11/2005 10:39 PM
Quote
Seems to me that you answered your own question. If it was originally a 235 then put one back in it.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#12902 03/11/2005 11:30 PM
Jerry, I'll take to heart what you are saying about the engine running hot. It has always run hot, but I attributed that to the fact that my Dad told me the heat sender unit on the head is off of a 350. I just bought the correct one (right amperage for the guage and such) and will install it when I drain the radiator to install my new heat shutoff valve to my heater core. I'll see how hot it runs then. I do know that my Dad had the original 2 core radiator rebuilt into a 4 core. There is currently a five blade fan on it with a deep pitch to the blades. I'll look into the 7 blade. Thanks
#12903 03/12/2005 12:15 AM
I'm running a 454 in my 63 4X4. There isn't anything that truck can't pull, except away from a gas station,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#12904 03/14/2005 6:23 PM
Whoops, the picture of my truck disappeared, Here she is again.
From my gallery page
Shane -- Sorry that I missed the pix on your gallery page. Got it up there now, so it won't disappear from the other web address. So I fixed it here on this link since this image is a better size.
Peg
