3 members (Gib70, Nick in Manitou, Wally / Montana), 104 guests, and 4 robots.
Topics128,088
Posts1,055,998
Members48,430
#1288571 11/23/2018 10:13 PM
My panel truck has '52 doors with the vent window. To install new glass run channels will I have to remove the vent window or is there a trick where I can get the channels in with the glass still installed? Or a trick to removing the glass without disassembling the vent windows?
I've done '50 doors before with 1-piece windows; it was easy to remove the glass by tilting it. I don't see how I can do that with wind wing division bars in the way. How about it Alvin - I know you've done this!
1951 Chevy Panel Truck
Your asking a lot....that is the one thing I did not photo when doing my panel a few years ago and i took mine out for new glass and channel. I glued my channel in and its held now for 5 years or more. I did the driver side first and it took me an hour and a few tries to get it in and to get the window glass fitted in the wing vent channel as I had to sort of "twist" the frame a little.....and naturally, the other side went smooth as silk.
I can look at mine later but its my opinion that if that is all your replacing you can do it without taking the assembly out.
You won't have to remove it, but you will have to un-bolt it so you can move it around the opening.
Thanks, but that's kinda "good news, bad news" - It's the unbolting that's the hard part! I guess I may as well remove it to get it out of my way :-(
I think it all depends on how you plan to attach the new channels. Glue or similar, you might be able to leave the wing window somewhat in place. If though, you plan to rivet in the new channel, I 'd think removal would be necessary.
Craig
Not hard once you do it a few times.
