6 members (Bill Hanlon, Donf, MickeyP, Hotrod Lincoln, mick53, FAST55), 109 guests, and 1 robot.
Topics128,049
Posts1,055,701
#1288207 11/20/2018 9:42 PM
Has anyone replaced the spring on the finger lever on the 4-speed transmission shifter?
If so please tell me the process and where to get the spring.
Harold
Harold
1952 Chevrolet 3800 pickup
---All pictures---
If you are talking about the 4-speed non-synchronized transmission with reverse lockout, Jim Carter has them. They are his part number MET137. Document by camera the orientation of the broken spring, then grind off the rivet holding the spring. Replace spring and use a bolt, rivet screw or rivet to replace the rivet you just removed. I had a blacksmith make me a rivet the last time I had to do this so it would look sort of original.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Sorry, I was thinking compression spring on shifter near the “finger” that does the shifting..
You’re asking about reverse lockout on the model before the SM420 in 1948.
---All pictures---
C Online: Content
Is this the spring that helps hold the shift lever rod in place, aka: shifter retention spring? If so, at worst case I'm sure you can find another compression spring at a local hardware store.
Craig
Kent
That is exactly what I was looking for.
Harold
Happy Thanksgiving
Harold
