| | | Forums66 Topics128,050 Posts1,055,753 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Has anyone replaced the spring on the finger lever on the 4-speed transmission shifter? If so please tell me the process and where to get the spring. Thanks, Harold
Harold Is a restoration ever finished? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | If you are talking about the 4-speed non-synchronized transmission with reverse lockout, Jim Carter has them. They are his part number MET137. Document by camera the orientation of the broken spring, then grind off the rivet holding the spring. Replace spring and use a bolt, rivet screw or rivet to replace the rivet you just removed. I had a blacksmith make me a rivet the last time I had to do this so it would look sort of original. Kent | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sorry, I was thinking compression spring on shifter near the “finger” that does the shifting.. You’re asking about reverse lockout on the model before the SM420 in 1948. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Is this the spring that helps hold the shift lever rod in place, aka: shifter retention spring? If so, at worst case I'm sure you can find another compression spring at a local hardware store.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Kent That is exactly what I was looking for. Thanks, Harold Happy Thanksgiving
