| | | Forums66 Topics128,211 Posts1,057,469 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | My firewall looks like Bonnie and Clyde drove it into the ambush. All original, yes, but way too many holes. I plan on keeping the main hole in the upper driver's side, the steering shaft hole, and the heater hose hole and whatever needed for brake and Ebrake. The rest I plan on closing up. I have been told the easy way is to weld washers into the holes. Anyone here have other methods I might use?
~Jim
| | | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 63 | My firewall had more holes than a politician's promise. Perry (bodyman) used a mig welder on the smaller holes with a piece of aluminium placed against the panel on the inside. Mig Weld does not stick to aluminium. Larger holes were filled with a patch panels. Small holes with a mig welder larger holes with oxy and hammer and doly Make sure all holes are cleaned with wire wheel or small sander before any welding
regards andrew | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Knockouts from electrical boxes worked on a couple holes for me. There are various sizes also. Dan | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | BIG CHEVY 3600,
This falls more in line of hot rod stuff, but on my '51, I cut a piece of aluminum to cover the firewall. I polished it and pop riveted it on, then used a single hole for my access to the under dash area.
It sure cleaned up the engine compartment, and the polished aluminum reflected the fancy engine.
Stuart | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | now you may laugh at this one .....lol But i used small pcs of sheetemtal cut into the size needed ...painted a whole bunch of them and after the paint cured i JB'd em to the inside of the firewall to cover my swiss cheese look. after they dried i just bondo'd over the holes and sanded smooth . | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Depending on the size of the hole, use copper as a heat sink backing and mig weld shut, kinda like a plug weld then grind smooth. Larger holes or imperfections may require a sheetmetal patch cut to size and mig welded in. | | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | i use a little pencil magnet to hold the patch panel while i tak it on | | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | I'm going to cut sheet metal pieces and bond them on with lord Fusor bonding agent. | | |
